attention 265 gurus!!!!!!!
Discussion in 'The Hokey Ass Message Board' started by jhouse88, Feb 19, 2014.
  1. jhouse88
    jhouse88
    from toledo
    i bought a 265 from an old 2dr 55 chevy. it is said to be a good running engine. its really nice with a edelbrock single plane and corvette finned valve covers. my question is what are my trans options. i understand it requires a starter adapter. will a 265 manual bell housing with the old starter mount work with a later saginaw or muncie? is there a special pilot bushing. will a later flywheel work with the old style starter? what would a clutch option be. i was gonna use a starter adapter to a th350 but i got a stellar deal on a nice sag 4 speed.
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Yes, later 3/4/5 speeds are the same pattern as the '55 bell housing, although the diameter of the front bearing retainer may or may not be the same. Stock pilot bushing will work with later transmissions, and any 168 tooth flywheel up to 1985 will work.
  3. squirrel
    The difference is that trucks starting in 1968 mostly used a larger size hole in the bellhousing, to work with the larger diameter bearing retainer on the SM465 granny 4 speed introduced that year. Truck saginaw 3 speeds usually have the larger retainer, you can swap to a car retainer to use the bellhousing with a small hole.
    Trucks from 55-72 used a bellhousing that mounted to a crossmember, and had a starter mount for the same 3 hole starter used on the 55-or so chevy cars.
  4. racemad55
    racemad55
    Least desirable of the early sbc's for the formentioned lack of oil filter unless your doing a numbers matching 55 project,my suggestion is to try to sell and get at least a 283 or 327.
  5. classic gary
    classic gary
    Don't forget about the camshaft, it's special in that engine.
  6. racemad55
    racemad55
    And the dist.
  7. timwhit
    timwhit
    I have a four door I'm fixin to sell. What's different about the cam and distributor?
  8. brigrat
    brigrat
    from Wa.St.
    Nothing if there a matched set!
  9. Bad Daddy
    Bad Daddy
    Really? I guess all them guys with flatheads should sell them for a later model engine with an oil filter. . .The '55 265 in my coupe runs just fine without an oil filter. Just do regular oil changes and you'll have years of reliable service.
  10. squirrel
    Something to do with oil getting to the lifter galleys. There's a flat on the rear cam bearing journal, and the distributor body has some funkyness where it fits in the oil p***ages.
  11. Shaggy
    Shaggy
    from Sultan, WA
    Honestly, you'll be best off trashing the edelbrock single plane, they aren't worth a damn at low rpm's due to the lack of runners letting the air switch directions back and forth as valves open and too big for the small amount of air even a warm 265 will pull
    As for clutch, a big 11" clutch certainly wont fit in an early bellhousing, and some others might not fit also....
  12. jhouse88
    jhouse88
    from toledo
    Great info guys. I knew the cam was different but did not know about the dizzy. I have a core 1965 283 but wanted something a little less belIy ****on than that. I like that it has now side mount provisions. I kinda prefer stock so the edelbrok will go for a stock setup with a dual quad factory set up in the future.
  13. dan c
    dan c
    as i recall, to put a later cam (or aftermarket cam) in that engine, you have to cut a flat spot on the rear bearing of the cam--something about oiling.
  14. snaptwo
    snaptwo
    You could use an old Lakewood bell and the block plate , it has the bolt holes for the early starter and will accept the Muncie , T10 or Sagnaw.. It also has provision for the trifive rear mounts.. Hey , if it runs okay , leave it !
  15. Ole don
    Ole don
    Simply remove the cam from the 265 and make sure the new cam has a slot on the rear as big as what it was on the old cam. You can grind the slot in at home.
