Attention 394 olds experts
Discussion in 'The Hokey Ass Message Board' started by langy, Oct 17, 2008.
  1. langy
    langy
    Seeking some help here, when i got my Olds 394 it was a box of bits as someone had already dismantled it.
    I have the following 2 questions
    Firstly i have this left over from the short motor build, I'm presuming its maybe the fuel pump pushrod ??? can't see where else it would go ???
    Secondly i got a new oil pump a Melling M22F which according to Melling is the correct one for my 394 but its different to the one that came with the engine and don't fit no way as you can see from the pics ???
  2. HEATHEN
    HEATHEN
    from SIDNEY, NY
    I'm quite sure that 394 Oldsmobiles don't have a fuel pump pushrod. Also, you must have an early 394; I think that the new oil pump you've got only fits the late ('62-'64) engines, and is the same pump that the next generation of Olds engines used.
  3. langy
    langy
    I did wonder if there were early and late pumps, Melling don't appear to list the early pump, Don't suppose you could point me in the right direction to get one ???
    I don't have the old fuel pump but i would guess it to have the long arm that runs on the concentric on the cam. Still puzzled what it is though ??? I suppose it could be from something entirely different and just found its way into the box of bits before i got them !!!
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Terrill Machine in TX sells vintage engine parts for Oldsmobiles. I've dealt with them before; check 'em out.
  5. langy
    langy
    Thanks will do.
    Cheers
    Steve.
  6. ROCKET88COUPE
    ROCKET88COUPE
    from TEXAS USA
    ross lombardi--330 544 4466 has every thing u need plus he knows oldsmobiles
  7. that spring bolt thing goes on the timing gear that is on the end of the cam, pushes against the timing cover, i have the oldsmobile oil pump part numbers at home, will post later, the pumps interchange with the 455 olds engines too.
  8. 56olds-ERDY
    56olds-ERDY
    yeah i think most stuff for sale groups all the 394s togather.looks like you need a 59-60 pump.the dist. drive is 59-60 only also.other ones are 61-64.if you cant find one anywhere else i belive fusik has them.i think they carry new gears to rebuild the one you have also.good luck
  9. langy
    langy
    Thanks i just found out its the Cam ****on, i now feel pretty stupid as i considered it to be that months ago but disregarded it as i didn't think the 394 had one 8-(
    Thanks for all the help guys, Its very much appreciated, Its not that easy building an old engine in the U.K. so we have to rely on the HAMB guys a lot, You have not let us down yet :cool:
  10. Paul
    Paul
    Editor
    another piece that is occasionally forgotten is the oil slinger,
    a large thin washer that goes on the end of the crankshaft in front of the timing gear
  11. Paul
    Paul
    Editor
    also,
    in your other thread you have a picture of your motor in mock-up
    those heads look to be late 371 heads, '59?
    are you sure you have a 394 block, (and oil pump) there?
  12. 2Hep
    2Hep
    the first photo looks the the pusher that goes on the timing chain cup behind the water pump (the "cup" over the gear with 3 bolts and ontop of the cam)
  13. langy
    langy
    Engine number says its a 59 394 Paul, 41/8" bore, Blownolds helped me ID it.
    Thanks for the heads up with the Oil slinger, Mine is missing but if i can get the dimensions i can make one if it comes to it. Don't suppose you can help with the dimensions can you ???
    I havn't fitted the timing cover with gasket until i found out what the ****on did :cool:
  14. yorgatron
    yorgatron
    i bet if i have a look around here i can dig up an oil slinger and send it to you.
  15. langy
    langy
    That would be a help mate, Swap ya for a late pump LOL
  16. HotRodChassis
    HotRodChassis
    Alliance Vendor
    I'm glad someone said something. Folks forget there is an early AND a late 371, as well as an early AND a late 394.
  17. Paul
    Paul
    Editor
    if George doesn't come up with a slinger I probably have one.. somewhere
  18. langy
    langy
    Panic over guys, Tony (goatroaper) has sorted the bits for me, Very nice helpful guy.
    Cheers
    Steve.
  19. Paul
    Paul
    Editor
    Tony comes through again!
    Steve,
    here's those pictures I mentioned..
    on the really grungy motor is the early flat style, as on this '53 303
    and on the slightly less grungy motor, a '59 371, is the later stepped style
  20. langy
    langy
    Thanks Paul, Saves me a little work :cool:
  21. Blownolds
    Blownolds
    from So Cal
    The oil pumps from '60-back are different from the '61-up oil pumps. The Melling pump is for '61-up. If you need an early pump then you will have to go with a rebuild most likely (although, who knows-- perhaps someone might be offering new ones these days).
    The cam ****on and spring go into the nose of the cam. I believe this is for '49-62. I do not recall seeing those in the '63-4 394's that I have torn apart.
  22. Mopar34
    Mopar34
    Fusick's has oil pumps and other parts for Oldsmobiles. Check out their catalog #410 for pumps and other stuff for pre-1960 Olds. www.fusick.com
  23. HotRodChassis
    HotRodChassis
    Alliance Vendor
  24. langy
    langy
    Thanks Nate, As always good advice.
  25. Blownolds
    Blownolds
    from So Cal
