Features Auburn Style Dash ?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Jul 9, 2009.
  1. cruzr
    cruzr
    :eek:with a tilt column???????.......go figure
  2. 5window
    5window
    Quite true, but one of the points of this thread was about how very many Deuces utilize the Auburn style dash. Probably about as many as use a Deuce dash in an A. I was only making a comment/suggestion, and I do give you credit for making something yourself rather than buying an off-the shelf unit which, nice as they are, most of the dashes on this thread really are. Nothing wrong with that either, in moderation.
  3. Tudor
    Tudor
    from GA
    Here's mine - I didn't want to have the same as everybody else.
  4. Silent_Orchestra
    Silent_Orchestra
    from Omaha, NE
    Man that's a purdy interior....
    The auburn dash is cool, the Knecht ones look really nice.
    Hey what are the gauges that are in it now?
  5. To hell with using one them get you one of these......................
  6. lurker mick
    lurker mick
    I did!
    Mick
    kidcampbell71 likes this.
  7. HOTRODPRIMER
    HOTRODPRIMER
    Mick,,I always liked that dash''
    That was my pal chopper's 3 window,,you got a great deal on a really nice car,,If I had been short and not 6'4" it would have been in my garrage. HRP
  8. b-a-r
    b-a-r
    from Oakland
    Put a Kencht in my 3/w.. If you do go with one, be sure to decide on your gauge size/brand before ordering. Hole spacing is different on S/W gauges and Autometer.
  9. Stu
    Stu
    here's a ***y looking panel
  10. Harrison
    Harrison
    That's Kaydub's panel & gauges.
    JH
  11. Stu
    Stu
  12. kaydub
    kaydub
    from Cali
  13. HOTRODPRIMER
    HOTRODPRIMER
    Looks nice!
    Is it a one off or is it some type of production piece? HRP
  14. kaydub
    kaydub
    from Cali
    I believe it's a "GM Diesel Powered" dash panel. This a "Straight 5" version and I believe they had a 10 gauge version also. Not sure what year they came in though......
  15. Harrison
    Harrison
    On my panel like Kaydub's, the square in the center above the gauges had "GM" stenciled on it. I painted my background black (I like Kaydub's gray better). I then took a round "Ford" script hat pin with a blue background, removed the pin part, & epoxied it in the square area. It looked really nice.
    Kaydub is right though, they came in big GM trucks.
    JH
  16. GavinEthan
    GavinEthan
    from Detroit
    Here is one I picked up for my '32. Sorry about the pics, old *** computer. It's got an engine turn insert, thinking about doing a differnt finish on it.
    It kinda combines the Auburn style and Stewart Warner styles into one...
  17. Harrison
    Harrison
    That would be gorgeous nickel plated with the engine turned panel and a polished lower insert.
    It'd damn-near be jewerly.
    JH
  18. Stu
    Stu
    david lane does great work--cant wait to see it done
  19. Kail
    Kail
    from Austin, TX
    This makes me rethink my dash
  20. GavinEthan
    GavinEthan
    from Detroit
    Good idea. I'm also thinking about painting the insert the same blue as my roadster, leaving the 'surround' polished as it is.
    I will post pics when it's complete. Still need gauges...and a running car...
  21. Steves32
    Steves32
    from So Cal
    For reference- the aftermarket ones are all different sizes.
    Mine is a Hotrod Garage, it's all aluminum w/ no SS insert OD is 14.5" x 6". It tarnishes so needs constant polishing- which I hate. The engine turning is wearing off as you can see in previous pictures of mine. You can specify spedo hole size at either 3 1/8 or 3 3/8.
    The Knecht is aluminum w/ stainless inserts. OD is 14.75" x 5.8750"
    Probably the nicest looking of the bunch & most expensive. Probably matches the bottom curve on the 32 dash the best. You can specify spedo hole size at either 3 1/8 or 3 3/8.
    The So-Cal one is aluminum w/ stainless inserts as well. Doesn't have the "pop" of the Knecht insert but is probably closer to the real Auburn less the lip. They list the measurements OD 18.5" x 8" but I'm not sure, may be a error. 8" would put the bottom an inch below the dash! I'll have to call.
    They also only list a hole size of 3 3/8" so if you plan on a black face Autometer, you are sol. It does say machined in house, I wonder if they can go 3 1/8 if you ask?
    Reason I brought this back up- thinking about swapping out mine while all my gauges are out. Mine alwaqys looks dirty unless I hit it w/ some semichrome.:eek:
  22. the metalsurgeon
    the metalsurgeon
    from Denver
    i like these!29 and 32 roadster shown.....
  23. JonnyAce
    JonnyAce
    :eek: That insert is slick! What is it, who makes it, and where can I get one?
  24. HOTRODPRIMER
    HOTRODPRIMER
    The thread is 4 years old but that's a old Stewart Warner dash insert,most likely was in a boat. HRP
  25. JonnyAce
    JonnyAce
    Thanks, man. I'll go check that out. :cool:
  26. Hybrid_Vigor
    Hybrid_Vigor
    I know this is an old thread but I found it useful. Karl Knecht told me today (7-23-2020) he is no longer making instrument panels which is too bad.
