August 2012 banger meet
Discussion in 'The Hokey Ass Message Board' started by Hapydz, Jul 31, 2012.
  1. noboD
    noboD
    An amish machine shop close to here welds castiron. They just did a one of a kind engine block for someone I know. Someone had fitted valve seats too tight and cracked the block at almost every seat.
  2. JEM
    JEM
    Indeed.
    Your head is in good hands.
  3. class 'A'
    class 'A'
    from Casper,Wyo
    Doesn't someone here have a T5 adapted to an 'A' engine?
  4. Crazydaddyo
    Crazydaddyo
    I do
  5. Crazy
    What is the head on the middle picture?
  6. Crazydaddyo
    Crazydaddyo
  7. elmitcheristo
    elmitcheristo
    Hello,
    I picked this head up at a swap meet this last weekend because it was interesting and most importantly, cheap. After a little research, I have found that Ricardo designed improved heads for the Model T Fords. But, this one looks a little different than a "T". The water inlet is cut back at an angle and it is more square on the left side and rounded on the right. I'm just curious to know more about it and if anybody does, it will be you folks.
    Thanks in advance,
    Mitch
  8. Crazydaddyo
    Crazydaddyo
    Show us the other side. We need to see the water pasages.
  9. elmitcheristo
    elmitcheristo
    Here you go.
    Thanks,
    Mitch
  10. The37Kid
    The37Kid
    looks like a Dodge Brothers item, noboD will confirm it I'm sure. Bob
  11. Crazydaddyo
    Crazydaddyo
    I don't think it's Ford. Here is the T lay out:
  12. Crazydaddyo
    Crazydaddyo
    Interesting shape of the combustion chamber.
    I thought that Winfeild had to stop using the "Crows Foot" shape because it was Ricardo's patent.
  13. Magnus B
    Magnus B
    Where did you find the lifters? Are there more? I might need a set.
    Thanks,
    MAgnus
  14. noboD
    noboD
    It surely does look like Dodge Brothers. The boss in the front would be for the fan. IS it for sale? What is the pat. date, can't read the year.
  15. RichFox
    RichFox
    Went out to the garage and it sure looks Dodge Bros. to me also
  16. Does look like DB- could you give the overall dimensions (that might help)?
  17. elmitcheristo
    elmitcheristo
    Thanks for the quick identification. The patent date is Nov. 13th, 1923. Overall dimensions are 8" by 21 5/8". And yes, I will probably sell it as I'm not much of a Dodge guy.
    Thanks again,
    Mitch
  18. Terrill machine in De Leon Texas is a source, 254 893 2610 I believe they manufacture them.
  19. noboD
    noboD
    PM sent.
  20. Hmmm, will that be going on the '25 Doug :)?
  21. Brendan1959
    Brendan1959
    OK Banger experts, I am going to fit my new snyder 6.1 head this weekend, I have new studs and a B type gasket. Should I spay the gasket with copper spray? I did this with the existing second hand copper head gasket and got no leaks. but I am unsure about this new gasket.
    Brendan
  22. RichFox
    RichFox
  23. BCCHOPIT
    BCCHOPIT
    Did Snyder say to use a B gasket?
  24. Excellent point.Call up Snyders.
  25. BCCHOPIT
    BCCHOPIT
    You said your old gasket was copper. Is your new one copper also or the new style. If it is copper yes spray it.
  26. Brendan1959
    Brendan1959
    Snyder instrusctions say no sealer. My last gasket on the stock head was copper sandwich and had been used but did not leak with copper spray, the new gasket is completly different see pics.
    Brendan
  27. Those gaskets? They work fine with no sealer. Thomas head clamped to a B block for thousands of miles now over the past 4 years - never had a problem.
  28. RussTee
    RussTee
    A little problem has cropped up on my build and I should have checked earlier. It looks like I may have model S Winfield carbs instead of SR carbs, not being famillia with Winfields I did not notice to now they are in good condition and I am trying to keep the build period will this effect the performance much on a street motor? Winfield use to say the S carbs did not need an accelerator pump but then later produced the SR. Your thoughts please.
  29. Bluto
    Bluto
    My guess it's more important on an 1/8 mile than 1/4 mile :D
  30. Brendan1959
    Brendan1959
    OK its on, no sealer, I broke one stud, luckily it was at the front, I tried the weld on a nut trick about 4 times and could not get the weld to stick to the stud. So I drilled it out and re tapped it. I have run it for 20 mins as per the instruction and will re torque it in the morning. Then off for a drive for fathers day.
