Technical *** August 2015 Banger Meet - August? Already? ***
Discussion in 'Traditional Hot Rods' started by Jiminy, Aug 1, 2015.
  1. V4F
    V4F
    from middle ca.
    OMG .......... yes ... thank you much & I owe you ............ steve
    MJW likes this.
  2. V4F
    V4F
    from middle ca.
    its like coming home !!!!!!!!!!!!!!
  3. 30ccpu
    30ccpu
    Hi larry how are u finding the lion head on your set up. I have recently put one on mine ImageUploadedByH.A.M.B.1439415504.824989.jpg
    Dannerr and ROCKER77 like this.
  4. 97
    97
    Does this mean you have changed your mind about the extra 4 cylinders? :D
  5. Thanks, I thought maybe you found the site I was looking for...
  6. V4F
    V4F
    from middle ca.
    yep , going to get my banger back tomorrow .................. I screwed up on the deal on the V8 ............. steve
    I have a lion 3 head on my banger , awesome torque ! love the head
    Dannerr likes this.
  7. Carter
    Carter
    Message_1439295374238.jpg Any of you guys recognize this water pump casting? Looks to be Miller/Cragar pattern on the head side, and has the same type water neck mount. Br***, unmachined, shorter than any Miller/Cragar pump I've seen.
    Thanks.
  8. 30ccpu
    30ccpu
    Vf4 are u running a cam as well ?
  9. '27 Coupes - all the rage this month! Love it.
  10. winduptoy
    winduptoy
    Like the way the head wakes the engine up.
    In route to Jamestown but had banger problems in Santa Few so I'm in a car that has 4 too many cylinders
    Red looks like a Fire Engine. Does it run like a house of fire?
    Sent from my XT1080 using H.A.M.B. mobile app
  11. I'm glad to see you back!:D
    That is the coolest avatar!
  12. 30ccpu
    30ccpu
    Yes Iam very happy how it goes have a stype cam as well and plenty of get up. Just fitted an overdrive and pulls that well
  13. hot-irons
    hot-irons
    Hey guys. Thought I might add some photos of the banger powered project I'm working on. I will be running a healthy B motor with a Chevy ohv conversion. Thanks for all the good info everyone.
  14. Jersey Joe 67
    Jersey Joe 67
    from J Town
    Great day for a cruise!
  15. Is that a Neil Jern Thunderbolt conversion?
  16. hot-irons
    hot-irons
    I have a lead on one but if that doesn't work out I have a great friend and amazing engine builder from outside Denver who is building the motor and will fabricate the adapter.
  17. I was just wondering cause a friend of mine has bought all of Neil's inventory and is running the business! He's in Anderson ca.
  18. Bill stipe modified a SBC head to fit on his engine
  19. You know we all like pictures on this thread?
  20. Crazydaddyo
    Crazydaddyo
  21. hot-irons
    hot-irons
    Here's my rough draft.
  22. hot-irons
    hot-irons
    That's wild. I read that a few years ago, he really wanted to run that set up bad to through all the work.
  23. waxhead
    waxhead
    from West Oz
    Does anyone know of a comparison between a lion speed head 3 and a crows-foot Winfield?? Or has anyone on here run both heads??
  24. 30ccpu
    30ccpu
    Hi waxhead I haven't run both but I have just fitted a lion 3 head and really like it
    waxhead likes this.
  25. V4F
    V4F
    from middle ca.
    Here's my rough draft. I wish it were mine . good for you ........... steve
  26. V4F
    V4F
    from middle ca.
    yes , "B" type cam , aluminum rods & pistons , counter weighted crank balanced + a lil more ....
  27. I haven't run a Lion head but I have run a repop al Winfield "Crowsfoot". Here is a photo of the results in 2010. I know most have seen this before but as some one recently said that we like photo's so here it is again. The car weighs 1500 Lb. and was running just under 3800 RPM's. All I have seen regarding the Lion head are Dyno reports.
    waxhead likes this.
  28. rogeroadster
    rogeroadster
    from Corona, CA
    Does anybody in the group have any experience running Weber 40mm or 45mm DCOE side draft carbs on a street driven Cragar B motor? This is a very mild motor with .080 over pistons, stock oil system and a Brierley 270v cam. Will be installed in a 26 T roadster with a T-5 and a QC rearend. With the Cragar being a 2 port, two carbs might be over kill but would look nice although not quite period correct.
  29. waxhead
    waxhead
    from West Oz
    Thanks Bill. What CR is your crowfoot Winfield head??
  30. V4F
    V4F
    from middle ca.
    I have a 32-36 weber on mine but not a side draft . great carb ......
    Dannerr likes this.
