Technical ***August 2023 Banger Meet Thread - Sleepy Days of Summer***
Discussion in 'Traditional Hot Rods' started by Jiminy, Aug 2, 2023.
  1. Outback
    Outback
    from NE Vic
    I've been wading through the Chevy 4 banger thread, been at it for days, so much inspiration!
    I'm about half way through the 80 pages!
  2. Stovebolt
    Stovebolt
    metalhead140 likes this.
  3. Stovebolt
    Stovebolt
    These looks alright - I will see if they have them. haven't found anything in the same size that matches the good old Firestone I run on the rear/
    winduptoy likes this.
  4. grumpy gaby 2
    grumpy gaby 2
    When you get through the 80 pages there will be a quiz!
    But luckily for us old Farts it's open book!!!!
    Outback likes this.
  5. Outback
    Outback
    from NE Vic
    Haha I'll let you know for sure!
    I was nearly inspired to jam a 28 Chev head onto my A, unless @Jimmy B has a spare Olds head for me! Hahaha :D
    grumpy gaby 2 likes this.
  6. Outback
    Outback
    from NE Vic
    They use Blockleys at the track, I'm considering a pair of 18's for my RPU
  7. Kevin Pharis
    Kevin Pharis
    from Califunny
    Was messin with an airflow simulation today, and so will be turning my choke horns so that the airflow doesn’t crowd into the intermediate circuit. With my horns turned toward the rear bout 75% of the air is directed to the intermediate side of the carb, turning them inline with the bodies should balance the flow to both circuits. Pretty obvious that straight choke horns would have a far more laminar flow, but the 90 deg horns have “the look”. I don’t suspect that I will notice a difference in how it runs, but it can’t hurt
  8. Outback
    Outback
    from NE Vic
    Those carbs look great! & Facinating how simple changes can make a difference & then how much or little that effects the way a car runs.
  9. set me on fire
    set me on fire
    had the old trucks up at my brothers place and had a visit from some wild horses that roam the neighhhh-borhood
    and did a weekend camp out Resized_20230815_073329.jpeg 20230813_154429.jpg 20230720_172226.jpg
  10. Airborne34
    Airborne34
    from Texas
    What would be a good compression reading for a Riley 2Port. I had looked at an engine that had 70-85 PSI, in # 1,2 & 4, and had 50 PSI in #3. Oil in cylinders pumped it up 5 PSI per cylinder.
    Outback likes this.
  11. Outback
    Outback
    from NE Vic
    IMG_20230820_223853.jpg I moved the rpu for the first time in 12 months, it fired straight up. Was nice to get it going!
  12. V4F
    V4F
    from middle ca.
    has anyone heard anything about the salt ?
  13. winduptoy
    winduptoy
    #3 is low and I guess I would do a cylinder leak down check to see where it is going? Past a valve or rings into the crankcase....the others are good in my mind....
  14. brokenspoke
    brokenspoke
    Why, Speed week was last week
  15. Outback
    Outback
    from NE Vic
    4 banger related?
  16. Yes, Speedweek was a week ago.
    We did not go, it flooded the week prior to the scheduled event.
    The SCTA held out and ran a shortened program starting Tuesday.
    From the live feeds, there were some records set.
    You can search up the livefeeds and some recordings.
    SpeedDemon won the HotRod trophy, I think around 332 mph, someone might have better intel.
    It sure looks like ElMirage had some rain today, still 3 weeks to event though.
    I won't be there, work has me traveling.
    J
    Outback likes this.
  17. 4bangerbob
    4bangerbob
    from AB, Canada
    There were 3 V4 records set in the banger cl***es as shown below.
    Driving to the course from land's end was through 2-3" of water, pits were damp with puddles.
    It did look like they were going to manage to have a 5 mile timed course on Tuesday (8 miles total) until the wind switched direction on Monday night and blew the water to the east which resulted in the first two miles not being useable.
    Bob
  18. V4F
    V4F
    from middle ca.
    thank you for info
    Outback likes this.
  19. 4BangerDean
    4BangerDean
    Did someone try to balance this “B” crank? I ***ume it didn’t have that many holes drilled on the counterweights when new. Should I keep it? IMG_3946.jpeg
    Outback likes this.
  20. Dan from Oakland
    Dan from Oakland
    Looks pretty normal to me. Those appear to be factory balance holes. What size are the journals? Did you have it magnafluxed?
    Old Dawg and stubbsrodandcustom like this.
  21. 4BangerDean
    4BangerDean
    I have not measured the journals yet. This crank came out of the engine that was in my truck. I’m hoping that the block checks out. I already have 2 counterbalanced cranks on the shelf and another in a running engine. This crank is just extra right now.
    I’m slowly gathering parts to build an OHV engine or at least hopes of.
    stubbsrodandcustom likes this.
  22. Airborne34
    Airborne34
    from Texas
    Who makes the extended shafts for the distributors? These are for engines with the Cragar or Riley Overhead valve set ups.
  23. 4bangerbob
    4bangerbob
    from AB, Canada
    for cragar try
    Steven Serr
    millerhispeedheads@gmail.com
    (805) 509-0893
    for Riley try
    Country Motors Ltd.
    cmtr81@yahoo.com
    920-349-8100
    Old Dawg and Airborne34 like this.
  24. GuyW
    GuyW
    [QUOTE="Airborne34, post: 14965229, member: 44167"WANTED: F.A.S.T. AKA "Ford A Speed Technology" Magazine
    1999 Issue #2. And. 2000 Issue #1 & #4
    2015 Issue #1
    2016 Issue #2[/QUOTE]
    Tangent: Is there any source to obtain scans of all the FAST Issues?
  25. Airborne34
    Airborne34
    from Texas
    /QUOTE]Tangent: Is there any source to obtain scans of all the FAST Issues?[/QUOTE]
    Not that I’m aware of. I had heard that there was an attempt at one time, but don’t think it was finished before the magazine was discontinued.
    In fact, I don’t even think the Secrets has been done as well. I know Charlie has started a Digital Version but I don’t believe that they are all available in one place.
    Outback and GuyW like this.
  26. Stan Back
    Stan Back
    Back to the BV records . . . you can run Gas in the Fuel cl***es and call it Fuel.
    If you can set the Gas Record and the Fuel Record in a cl*** -- more power to you!
  27. Outback
    Outback
    from NE Vic
    I was wondering why the Gas & Fuel Records were so close. Is that what happened in this case? I
  28. Dan from Oakland
    Dan from Oakland
    For fuel cl***, pretty sure all you have to do is break the seal on the tank, spit in tank and change the cl*** designation
    on the side of the car- change the "G" to an "F".
    Old Dawg likes this.
  29. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    I would almost put money on it being a valve not sealing or not adjusted right...
  30. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Or give it a shot of whiskey in the fuel tank.
