Projects Aussie 32 frame / Model A coupe build.
Discussion in 'Traditional Hot Rods' started by Wardog, Feb 7, 2019.
  1. 3blapcam
    3blapcam
    Hahahahahahah... that's a great point! They do have mountains... they might have a few spots high enough in elevation to garner freezing weather?! I don't know... maybe an Aussie will chime in about it...
    Couldn't wait for a response... had to Google it:
    3blap.
  2. Wardog
    Wardog
    The cracked block I was told came out of a car from South Africa. But the same guy who told me this took decent money from me for a “good engine to rebuild”.
    Outback and 3blapcam like this.
  3. Wardog
    Wardog
    July 2025. Ken ***embling valves. We used a melling high volume oil pump so I had to modify the pick up to suit the 8ba style pump. IMG_2564.jpeg IMG_2565.jpeg IMG_2568.jpeg IMG_2570.jpeg
    AHotRod and Deutscher like this.
  4. Wardog
    Wardog
    Thanks for the compliment.
    Yes, the transmission was completely my fault. I was messing around with my sons, dumping the clutch and doing little burnouts. First gear sheared it’s teeth and they came back around and forced the shaft down taking the case with it.
    Deutscher and 3blapcam like this.
  5. AmishMike
    AmishMike
    Still thinking about that dam crack. No water near to cause long crack like that. I have decided car or just engine took hard shot into oil pan on other side caused bolts to force crack. Maybe with pan almost off, fell off engine stand. Strange
  6. Wardog
    Wardog
    “THE CRACK”
    This seems to got a few people’s attention.
    That engine was cracked before I bought it.
    I don’t know or really care how or why it happened.
    The only issue with the crack is that it was not mentioned to me when I paid fair money for the engine. In fact the seller made excuses as to why we shouldn’t pull the oil pan when we were buying the engine. He knew it was cracked and a phone call after it was found and a partial refund confirmed it.
    The only part I used from that engine was the oil pan. The only other use was as a jig when modifying the oil pump pick up.
  7. Beanscoot
    Beanscoot
    That's good news that there's no water near the crack. It makes it a lot easier to save the block.
    So I guess it's not freeze damage.
    Dick Stevens likes this.
  8. AmishMike
    AmishMike
    Agree with “beanscoot” ^^^^. Seems block could still be used
  9. Wardog
    Wardog
    IMG_2580.jpeg IMG_2579.jpeg Mid July 2025. I would have been picking the engine up but the flywheel fouled the block. We figured out the problem and I got Ken the correct flywheel. It then had to be balanced to match the balanced rotating ***embly. We also cleaned up the pressure plate and bought a new clutch.
    Deutscher and swifty like this.
  10. Wardog
    Wardog
    IMG_2605.jpeg July 30 2025. Engine completed and back in my shed I added a timing pointer and notched the pulley for TDC. Prepping for paint. This is when I figured out my starter was not going to work. I put a call out on social media and my friend Tommy told me to come get the starter out of his 32 roadster project. It was the starter I needed and a nice catch up with my buddy.
    Nailhead A-V8, Deutscher and swifty like this.
  11. Wardog
    Wardog
    August 10 to 12 2025.
    Starter painted, engine painted, ch***is prepped, rebuild date painted on the back of the block. Ready to go. IMG_2624.jpeg IMG_2625.jpeg IMG_2626.jpeg IMG_2627.jpeg IMG_2629.jpeg IMG_2632.jpeg
  12. Wardog
    Wardog
    August 13.
    38 top loader fitted and the engine going in.
    August 15.
    Driveline all fitted up. Top end pulled apart for a tidy up and being installed on the new engine.
    Outback, AHotRod and Deutscher like this.
  13. Wardog
    Wardog
    August 18 2025. Engine complete. Still have to instal new spark plugs.
    August 19 2025. The starter motor would throw out but not turn the engine over. I spent hours removing it, cleaning electrical connections and trying again. Eventually we figured out the starter needed a rebuild, so that’s what it got.
    This removable starter cover was a real help in fault finding my problem. I could see it was throwing out but not turning the engine.
    Outback, AHotRod, Deutscher and 2 others like this.
  14. Wardog
    Wardog
    I ran the engine in with 3 15 minute heat cycles.
    September 01 2025. This is how the plugs came out after the running in and before any adjustments.
    I ended up having ignition troubles that kept me from taking the coupe to my club rod run. With a borrowed distributor I made it to its first car show with the new engine.
    October 12 at The ramones picnic.
    My friend took this photo of my coupe and my wife’s galaxie.
  15. Wardog
    Wardog
    There’s something about hand written specifications and invoices from a person in their 70’s.
  16. Wardog
    Wardog
    Now that I have gone from a 32 trans to a 38 trans the shifter is a little more forward.
    I had to modify my trans cover.
    In first photo I have cut the hole forward a bit more and half made the filler piece.
  17. Wardog
    Wardog
    The rear suspension has never been perfect.
    I added leaves to the rear spring and it made it worse. I figured out the spring was hitting the rails. So I removed the extra leaves but had to make a 3/8” spacer for the top of the pack to get the ride height where I wanted it. Then I notched the rails 1.5”
    The ride is a lot better and now I’m not bottoming out.
    Deutscher, wils0nmurphy, Tim and 2 others like this.
  18. Outback
    Outback
    from NE Vic, Oz
    Nice work mate, the coupe should run much better with these additions/improvement's
    Good to see :cool:
    Wardog likes this.
  19. Wardog
    Wardog
    I thought I should post a photo showing how the car sits after the rear suspension tweaks.
  20. Outback
    Outback
    from NE Vic, Oz
    That sit's so well! Looking forward to catching up in Yak
  21. Wardog
    Wardog
    For sure mate.
    Outback likes this.
  22. Outback
    Outback
    from NE Vic, Oz
    Call in for a cuppa on the way through if you want.
