Technical Austin Fender well Headers?
Discussion in 'Traditional Hot Rods' started by Deuced Up!, Nov 27, 2013.
  1. Deuced Up!
    Deuced Up!
    I am looking for a set of fender well headers (BBC) for a Gasser Application. Can anyone with one of the smaller cars like an Austin Dorset, Henry J or Anglia make a suggestion. Is there a header out there on the market that works with the smaller cars etc. or do I just need to build them?
    I have wondered about ones set up for a Nova?...My issue is obviously the overall width and trying to keep them in the fenders etc.
    Thoughts on the subject anyone?
  2. Deuced Up!
    Deuced Up!
    Outside of Header Collector to Outside will need to be around 48" to 50".
      491.9 KB
      335.9 KB
  3. You might try the******* Chevy II fenderwell #2280 , Hedman
    Husler makes several S-10 BBC swap headers (if you call them in
    Georgia) they can supply them unwelded(not any cheaper, just
    easier to modify). Sanderson does several over chassis exit
    for early fords (27-34) with different engine setbacks.
    I tried all the choices when looking for fenderwell headers for
    my Henry J gasser and could not find anything that cleared the
    firewall,chassis or tires without moving a tube or two,even with
    a smallblock. Building them still works out the best.
  4. Deuced Up!
    Deuced Up!
    Thanks, I will check some of them out.
