Auto to early Flathead?
Discussion in 'The Hokey Ass Message Board' started by LoneWolfNoCLub, Mar 31, 2011.
  1. I have noticed in my little bit of research I have done, there are no adapters for an Automatic trans to and early (36) flathead. I am paralyzed and will most likely end up doing my little hand-clutch conversion I have come up with using much help from felow disabled HAMB members. BUT, I am sure somebody, somewhere has made their own adapter plate(s) to use an auto behind an early flathead. If so, what parts were used? I am sure it will be easier to just put a newer flattie in there with an auto, but I have to check. Anyone?
    Thanks!
    James
  2. Shaggy
    Shaggy
    from Sultan, WA
    I believe there is a kit for a c4, but i dont speak automatic enought to know where
  3. nolly
    nolly
    For the early Ford f/h there isn't much choice,FlatOmatic seems to be the only one! http://www.flat-o.com/carproducts/flatomatic.htm
    If you go 49-53 you'll have a wider choice
    ,Wilcap,Speedway etc!
    Google 'Auto to early flathead' for more info. Good luck with your venture,James!!:cool:
  4. choppedtudor
    choppedtudor
    I'm using a WILCAP to run a GM 700r4 AOD
  5. rainhater1
    rainhater1
    from az
    I have known this guy for over 25 yrs, he is about the most honest person I have ever known. He started this company after he built one for himself. His dad started a transmision repair shop and he learned it from the ground up :)
  6. roseville carl
    roseville carl
    Yep you can't beat Gene at Flat-O-Matic, stand up guy and company............
  7. hombres ruin
    hombres ruin
    I second flat o matic they are awesome to deal with. I have had it mated to my flathead for years and never had a problem
  8. Thank you very much guys. I will give Gene at Flat-o-products a call.....
    James
  9. fiftyv8
    fiftyv8
    from CO & WA
    Remember, the more gears the better especially behind a flathead.
  10. mgtstumpy
    mgtstumpy
