AUTO TOMANUAL CHOKE (HOLLEY)
Discussion in 'Off Topic Hot Rods & Customs' started by Firefighter1618, May 20, 2024.
  1. Has anyone tried to convert an electric choke on a Holley 750CFM to a manual choke WITHOUT spending $50+ on the actual Holley Conversion Kit - which doesn't even include the choke cable?
    I'm thinking: remove the cover of electric choke, connect a cable to the choke thermostat somehow to be able to control the opening and closing of the ****erfly. OR get rid of the electric choke altogether and attached a cable to the ****erfly somehow in order to be able to open and close it.
    All help is greatly appreciated.
  2. onetrickpony
    onetrickpony
    from Texas
    I haven't seen one in years but at one time you could buy a cable with a loop formed on the end and a bracket. You took off the choke cap, installed the bracket, and attached the cable with the loop over the arm that previously went into the cap. It shouldn't be too hard to fab up something simlar.
    Deuces and 427 sleeper like this.
  3. Bob Lowry
    Bob Lowry
  4. Oneball
    Oneball
    I’ve not tried it but the Weber 32/36 with manual choke just uses a unit that replaced the bi metallic coil, which means you keep the throttle piston and all other gubbins. IMG_7937.jpeg
    Looks like Bob got there first
    Firefighter1618 and Bob Lowry like this.
