Auto trans help
Discussion in 'The Hokey Ass Message Board' started by 021k26rr, Oct 30, 2008.
  1. 021k26rr
    021k26rr
    from TN
    What auto trans will work behind a chevy 235 inline six.
    Thanks
    Ben
  2. locospup
    locospup
    wow....i am having the same problem.i have a 60 chevy brookwood with a 235...i was told 1958 235 and newer a turbo 350 will work...
  3. kustomkat
    kustomkat
    I'm no Chevrolet guy, but I think it depends on the vintage of motor you have. Put a TH350 in my buddys 54 and it required and adaptor. I believe somewhere in the early 60's an aluminum powerslide/TH350 will bolt right up.
  4. Jeff Walker
    Jeff Walker
    The only automatic transmission that will work is a cast iron powerglide that came out of a 235 powered car.
    Anything else will need an adapter.
  5. if you want a later trans behind the 235 you will need to purchase a adaptor. steve at buffalo engineering makes them. they are nice and expect to pay for one. in the $500 range.
  6. DrJ
    DrJ
    Or, for that you could buy a running later 250" 6 that will bolt up to the 350TH and run it instead of the 235"
    Nothing wrong with a powerglide (if you can rebuild in your area) and are still running the torque tube rear end you need it.
