1952-59 Ford Auto trans swap
Discussion in 'Off Topic Hot Rods & Customs' started by Dumptruck, May 22, 2012.
  1. Dumptruck
    Dumptruck
    Hey party people! I just picked up an auto trans to replace my three on the tree. My question is, is it a direct swap or do I need to make new mounts ect. I have a 215 manual trans in a 53 customline and the auto trans is out of a 54. I have the flywheel and torque converter for the trans also.
  2. missysdad1
    missysdad1
    Let me get this straight. You're gonna' take a good 3-speed manual out and put a used '54 Ford-o-Matic in? You're joking, right? If you're serious you're about to discover the true meaning of the word "slow"...
  3. Dumptruck
    Dumptruck
    Yup that's the plan. If I was concerned about speed then I would have done a V8 swap.
  4. missysdad1
    missysdad1
    Cool! I spent many years in the Los Angeles area and understand the concept of "low and slow" and can totally appreciate it...
  5. JeffB2
    JeffB2
    from Phoenix,AZ
    Having been down this road before when I did a rear end swap years ago your 3 speed rear has 3:90 gears with the Ford-O-Matic it will accelerate from a stop quicker but it will not like cruising on the highway as your 215 will be winding up pretty good.Perfect scenario would be swapping in a Maverick or Mustang 8" with the common 3:00 rear gears.If you do the swap your 3 speed column won't play well with the Ford-O-Matic so this is your best bet: http://www.summitracing.com/parts/SPE-6423/ it will work well and is a whole lot easier and cheaper than swapping out a column.
  6. Dumptruck
    Dumptruck
    The reason I'm swapping the trans out is because I'm loosing my clutch and pressure plate and they are way to expensive to replace it. I do have 3:90s in the rear end and I can't run the freeway anyway till I change out the gears. What I'd like to know is if it is a direct bolt in, as long as I change out the flywheel.
  7. rick55
    rick55
    Yep it is direct swap but don't forget to remove the Pilot bearing/bushing from the end of the crankshaft.
    Regard
  8. missysdad1
    missysdad1
  9. Retro Jim
    Retro Jim
    It's a direct bolt in but you must be looking in the wrong places for a pressure plate and clutch set up . They really aren't that costly at all . Then you will have what the car was originally set up for and will run nicely . I know it's your car but that is going the wrong way when it comes to a trans swap .
    If you look around the cost really isn't that much .
    Just my opinion !
    Jim
  10. alanfreeman
    alanfreeman
    from california
    You will also need to change the steering column or at least the outer column housing to one from a car which had an automatic transmission with the selector dial. You will need the correct linkage rods from an auto. car and a neutral safety switch. All of this could easily add up to much more than the cost of a clutch and pressure plate. Alan S. Freeman
  11. Even better is to throw in a T5. Adapter and new clutch/pressure plate. then the 3.90s will be a great cruise ratio. Ny 3.73s and a T5 combine for 2,000 RPM at 70 MPH.
  12. Dumptruck
    Dumptruck
    Thanks for the info.
  13. Custom_Crestline
    Custom_Crestline
    ford-o-matics are just a lot of trouble. YMMV, but I was glad to throw mine away.
