Autolite 1100 carb question
Discussion in 'The Hokey Ass Message Board' started by boilertech, May 25, 2012.
  1. boilertech
    boilertech
    from Bryan OH
    My 63 Galaxie with 223 in-line 6 has devoloped a problem and it's driving me crazy trying to figure it out...Was out cruising this morning and she just lost power (like it was out of gas). It starts right up but then cuts right off again. pulled the top of the carb and the bowl is full of gas, and it has a gl*** in line filter that is full, but i can't see any stream of fuel when i pull the accelerator and look down into the carb. pulled the top again and made sure the main jet was clear (it was) but same problem.
    Any help would be appreciated. There is a local car show tomorrow and the grand-daughter really wants to take the old girl.
  2. squirrel
    Sounds like an ignition problem. although if the accelerator pump isn't working, you probably should fix that.
  3. boilertech
    boilertech
    from Bryan OH
    Thanks Squirrel,
    I'm getting good spark, points look good...this is driving me crazy! :mad:
    Did make it through the car show with my grand daughter but just as spectators....oh well..
    Any more thoughts? Anyone?
  4. boilertech
    boilertech
    from Bryan OH
    Just as a follow-up: Found it to be the fusible(?) wire leading from the ignition switch to the firewall. It had a break in it and wasn't sending juice to the coil. Just when you think things are easy to figure out something comes flying in from right field! Back on the road!!! :D
