Autolite 4100 running extremely rich
Discussion in 'The Hokey Ass Message Board' started by kingdesgn, Dec 30, 2010.
  1. kingdesgn
    kingdesgn
    I just rebuilt my Autolite 4100 and now it running extremely rich (fat). Anyone have any suggestions on how to lean it up a bit? It sounds like it's missing. Checked spark plug wire placement and all seems to be in the correct order. This is my first restore. Thanks!!
  2. junkyardjeff
    junkyardjeff
    Recheck float level.
  3. scrap metal 48
    scrap metal 48
    you might check for a vacuum leak also.........
  4. kingdesgn
    kingdesgn
    hey s****....how should i check for vacuum leak...any special way of doing that? thanks!
  5. bobscogin
    bobscogin
    Check the power valve for damaged diaphragm.
    Bob
  6. Correct spec jets?
  7. mow too much
    mow too much
    <!-- / message --><!-- sig -->__________________
  8. grapp
    grapp
    what they said, recheck float and make sure needle/seat combo is working as it should.
  9. vncruiser
    vncruiser
    There is no power valve on an Autolite carb. Also, a vacuum leak would make it run lean...Re-check the float level...
  10. 1952henry
    1952henry
    True that
  11. grapp
    grapp
  12. 1952henry
    1952henry
  13. burnout2614
    burnout2614
    Say no to teflon tape on fuel threads!!!!!! peace
  14. rallisracing
    rallisracing
    4100s (and the 2100 two bbls) have what Ford called an economizer valve..It shut off fuel at higher vaccuum...Holley called them a power valve..same thing, and if the diaphragm is blown, it will flood just like a Holley does when the power valve is blown, usually resulting from a backfire...
  15. 2manytoys
    2manytoys
    from Fresno
    Is it dumping fuel down the venturies at idle? (check it by looking down the carb with engine running)
    Is it rich at all speeds or RPM?
  16. kingdesgn
    kingdesgn
    in looking and listening to my carb yesterday, i feel that i need to set my air fuel mixture....still running a little rich. anyone have any advice for tuning these?
  17. If you are SURE everything is working correctly, and no fuel is dripping down inside the carb at idle, set the idle mixture by screwing the idle jets down until they stop (DON'T tighten them), and back them out 1 1/2 turns. Start the car and adjust the idle speed to about 650 rpm. It should idle nice and smooth. If not, you have a problem somewhere.
    If it idles ok, open each idle screw 1/2 turn and watch (or listen to) the engine speed. If it goes up, reset the rpm to 650 and try again. At some point, the next 1/2 turn on the idle screws won't cause any increase on speed. Back them in 1/2 turn and you're done. If you get out past 3 turns and it's still picking up, you've got a vacuum leak somewhere.
    (Keep in mind this is only adjusting the idle mixture. If the engine is running rich at higher rpm, you need to re-jet. And again, ALL of this depends on the carb working correctly in the first place.)
  18. kingdesgn
    kingdesgn
    When I screw in the air / fuel mixture screws, the idle goes up and when I back them out, the idle goes down. Is this correct?
  19. bobss396
    bobss396
    I would slap a vacuum gauge on it and go with the highest vacuum reading.
    Bob
  20. neema14
    neema14
    from Michigan
    So I have the same problem, runs fat un-burnt fuel smell, looking down carb I see fuel leaking from the right front vetury. I have cleaned every port on carb, blew carb cleaner in every port, slot, hole. Replaced power valve, gasket sets, checked float levels, took top of carb off off and run car, still gas flows out ventury. Checked for vacuum leaks and all checks out Help me.
  21. neema14
    neema14
    from Michigan
    Idle adjustment screws do not effect idle, either
