Technical Autolite 4100 Running Rich
Discussion in 'The Hokey Ass Message Board' started by Oneball, May 7, 2024.
  1. Oneball
    Oneball
    I’ll try to give as much info as possible, my freshly rebuilt 352 FE with a 4bbl Autolite (also rebuilt but I’ve not seen it run on an engine before) is running rich at idle.
    It is not on the choke
    It sounds like it’s running rich
    It looks like it’s running rich
    A squirt of fuel in the carb makes it die
    Pressing the accelerator pump without the throttle makes it die
    It runs best with the idle mixture screws out about 1/2 turn
    Turning the idle mixture screws in any more to lean it off and it dies
    This all applies to both sides of the carb
    What has got me scratching my head is that if there was a problem other than the idle circuit then screwing the idle screws in wouldn’t kill it. If the idle circuit was too rich then leaning it off wouldn’t kill it.
    Timing is at 10 BTDC
    What am I missing??
  2. sdluck
    sdluck
    Not enough info?Fuel pressure,vacuums , is the motor stock? ETC
    Deuces and Oneball like this.
  3. Oneball
    Oneball
    Very mild cam, bottom of the Edelbrock catalogue, certainly not hot enough to cause poor burn at idle.
    Offenhauser 360 intake
    PCV system
    Stock pistons, new rings
    Stock ignition, mech and vac advance work
    Stock crank and rods, new bearings
    Stock heads, new valves and guides
    Stock fuel pump
    Not sure I trust my vac gauge as I noticed it’s not returning to zero, it was reading about 16”
    Carb is jetted for a 300hp 352 T bird
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Start with getting a new vacuum gauge.
  5. I wonder if the power valve or power valve gasket is bad. I agree though, you'd think turning the idle mixture screws in wouldn't kill it.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Let’s say it is 16. Did you change anything in regards to timing tab or crank dampener.
  7. Oneball
    Oneball
    Original damper and timing tab.
    I’ve ordered a new vac gauge
    Snicklefritz65 likes this.
  8. jaracer
    jaracer
    I second taking a look at the power valve. I remember replacing a few for very rich running.
  9. Oneball
    Oneball
    The reason why I don’t think it’s power valve is that i don’t think it runs through the idle circuit so if it was blown, screwing the idle mixture screws in shouldn’t cause the engine to die.
  10. miker98038
    miker98038
    There’s a lot of talk about 4100 over on the Yblock site, they (and the new, similar Summit version) have been pretty popular in the 1.08 and 1.12 versions. Everyone seems to be more like 1 1/2 to 2 1/2 turns out. If you’re still rich at 1/2 turn there’s fuel coming from someplace. Or an air bleed blocked?
    Oneball likes this.
  11. Oneball
    Oneball
    Fuel coming from somewhere other than the idle circuit would be my guess except for the fact that if you lean it off on the idle mixture screws it dies.
    Everything was stripped and blown through with air and carb cleaner when I rebuilt it.
  12. ClayMart
    ClayMart
    Does that carb have any idle air bleeds that might be plugged or restricted? At idle is it dripping fuel from the main nozzles?
    Oneball likes this.
  13. Check the base gasket where the carb meets the intake. Not sure about the Offy, but I know they don't seal well on an Edelbrock. Is the accelerator pump weight and ball check in correctly?
    Oneball and winr like this.
  14. What is your float level set at? I don’t know about the 4100, but the 2100 will run without the top cover on. Maybe if the 4100 is the same, it would help with diagnostics?
    Oneball likes this.
  15. AccurateMike
    AccurateMike
    Put it back together with the secondary jets in the primaries ?
    Oneball likes this.
  16. Oneball
    Oneball
    I will check
  17. Oneball
    Oneball
    I’ve double checked the gasket and from the witness marks it looks to be sealing correctly, I believe the ball check is in but will check.
  18. Oneball
    Oneball
    I’ve double checked the float level. They supposedly run with the top off but I’ve not tried
    ClayMart and Truckdoctor Andy like this.
  19. Oneball
    Oneball
    Shouldn’t make a difference to idle circuit
  20. Hotwyr
    Hotwyr
    I had a similar problem with the Holley version of this carburetor. Power valve was blown. I think I'd check that first to at least eliminate that possibilty before getting crazy with other options. These are a very basic carburetor and pretty trouble free.
    jaracer, Oneball and ClayMart like this.
  21. ClayMart
    ClayMart
    These old Autolite carbs did seem to be "stone axe" simple. Any time I ever had one apart I was always amazed that they seemed to consist of only 6 or 7 parts.
    From years ago I remember an auto tech instructor mounting one of these carbs in a bench vise with the bowl cover removed. He filled the bowls with water and placed a big shop vac hose under the throttle plates to simulate manifold vacuum so we could watch the workings of the idle, main and accelerator pump circuits.
    I'm not so sure that he didn't also have one of the students working a mechanical fuel pump with the inlet hose submerged in a bucket of water, to make sure you understood how the needle and seat worked. When this instructor taught you something, he made sure it stuck with you! Thank you Sam. . . You left us way too soon! ;)
  22. winr
    winr
    from Texas
    Was the 352 running before rebuild ??
    Did it have the Offy 360 intake on it and 4100 or other carb ??
    Was this the cam shaft ??
    Edelbrock Performer-Plus Camshaft Kit for Ford FE 352-428 V8 - Edelbrock, LLC.
    Shows 16" of vacuum .. does not say at what rpm
    My worn out stock 65 352 2 barrel with a 1969 390 2 barrel hi compression cam has around 18" of vacuum at idle
    A 4100 will not will not seal on an Edelbrock Performer intake, not sure what an Offy 360 carb flange looks like
    4100 will not seal on all Ford factory intakes as well without the proper spacer
    When the engine is idling, slowly cover the front inlet where the choke is and see if the rpm goes up
    This will indicate a vacuum leak/ too much air to fuel
    Do you have or can borrow an carb that is known to run good to bolt on ??
    Have you tried advancing the timing to see if the vacuum comes up ??
    I have Performer 390 intake on my 352, I had to add a 1" 4 hole spacer on the intake so the 4100 worked
    The complete outside of the 4100 bottom has to seal
    Oneball likes this.
  23. winr
    winr
    from Texas
    See the skinny edges on the outside of the carb, they must seal
    The triangle at the front of the carb must seal, it gives vacuum to the power valve
    Oneball likes this.
  24. winr
    winr
    from Texas
    The middle and back triangles must seal
    Oneball likes this.
  25. Oneball
    Oneball
    352 was running before rebuild but on the factory iron intake with a 2100, it was running rich as the choke wouldn’t come off.
    Cam is a Performer not the Plus
    I have a spacer and the gasket appears to show it’s fully sealing on all surfaces.
    I do have another carb but don’t want to take it off the Vette as I’m racing at the weekend.
    When I get a new vacuum gauge I’ll report back on the suggestions.
  26. Oneball
    Oneball
    The ball is there but no weight. I did a lot of digging about that and apparently not all had the little cylindrical weight
  27. Oneball
    Oneball
    Had the carb apart and can confirm the power valve isn’t blown.
  28. Pontmerc
    Pontmerc
    from Finland
    You sure pw isnt bottoming out?
    Sometimes i used double gaskets to prevent that.
  29. Pontmerc
    Pontmerc
    from Finland
    Blowing air isnt always enough, you gotta use correct size drill bit to open those air bleeds out with all dirt.
  30. Oneball
    Oneball
    What is PW?
