Hot Rods AUTOMATIC behind a FLATHEAD???
Discussion in 'The Hokey Ass Message Board' started by Nos1partstore, Jan 8, 2017.
  1. Nos1partstore
    Nos1partstore
    Hey guys,
    I have a good running flathead V8 in my 1950 Ford F1. However, due to a prosthesis, having a manual transmission is not a good option. Anyone ever put an automatic behind the flatty? I plan on keeping the stock rearend as well, unless it is necessary to change if I go with an automatic. Any help would truly be appreciated.
    Thank you
  2. rdscotty
    rdscotty
    from red deer
    55willys likes this.
  3. KoolKat-57
    KoolKat-57
    from Dublin, OH
    A friend has the flat-o-matic setup in a '32 Fordor hot rod, seems to work very well and trouble free!
    KK
  4. Hnstray
    Hnstray
    from Quincy, IL
    Your truck probably has rear end ratio very close to, or above 4 to 1. That would work for just around town, but a more 'user friendly' ratio would be in the low 3's. Given the parallel leaf suspension, replacing the rear axle ***embly is not too difficult.
    Ray
  5. Raunchy
    Raunchy
    I have heard they make a flathead "lazy" but have never got to drive or ride in one. Anyone have any feelings or experience on this?
    Sent from my SM-N910V using The H.A.M.B. mobile app
  6. southcross2631
    southcross2631
    I ran into a guy in Daytona who had a 51 4 door with a C-4 in it and he loved it.He said it worked great behind his flattie.
  7. ChuckWeck
    ChuckWeck
    from Chicago
    I also have a 50 f1 flathead with a 200r4 aod, used an adapter and built a pedal mounted linkage for the tv cable....works well
    Adapter is a wilcap, uses a ford style starter
  8. Aviator
    Aviator
    I have a 59AB flathead with a C4 transmission Used a flat-o-magic kit. Great set up.
  9. blackrat40
    blackrat40
    When I was 16 a friends dad had a '53 Ford sedan with a stock automatic. Same basic engine
    as yours. I would think it would bolt right up with no adapter needed. Might require reworking
    the trans. mount and shortening the driveshaft. Not a big deal to do that.
  10. teejay99
    teejay99
    My late father's 51 Monarch had a flattie and auto trans back then .
  11. Jalopy Joker
    Jalopy Joker
    as stated above, gears too low to work well with C4 but, should work with a 200R4
  12. bchra guy
    bchra guy
    Am using a C4 behind the 8BA flathead in my avatar 39 with 3:55 gears in the 8" rearend..........works well with a mild shiftkit in transmission..........likely would be better with a 5 speed, but bride can't drive a standard..........auto trans have come a long ways since early '50's..............also using Flat-o adapter kit including mini-starter..........
  13. Bill Rinaldi
    Bill Rinaldi
    Local flat head guru (Jim L****n) runs a 32 Hi Boy sedan. 59ab block. Jim put in a C4 and REALLY likes it!! He does run a quick change, so I'm not sure what gear he prefers.
  14. 3340
    3340
    I run a C4 behind 8ba 8 in 279 gear 235 75 15 in tires I couldn't ask for a better combination IMG_1483923954.564323.jpg
  15. Flathead Dave
    Flathead Dave
    from So. Cal.
    I have a C-4 behind my 8BA. I used the Speedway adaptor. $400 and you have to buy an early 1970's Mustang starter. Nice and easy set up. Using a Lokar Shifter.
    My brother did the same thing in his T Bucket. He had a 47 flatty in his. Nice easy setup and driveability.
    nailed31 likes this.
