Automatic to Manual conversion
Discussion in 'Off Topic Hot Rods & Customs' started by David Gersic, Sep 13, 2026 at 3:44 PM.
  1. David Gersic
    David Gersic
    from DeKalb, IL
    I don’t know if this fits on-topic or not, so I’ll put it here in OT land. I haven’t been on here much lately, but I’ve been busy. After ~10 years of driving my ‘37 Chevrolet as an automatic (700R4), I decided that it needed to be a manual five speed.
    The first hurdle sounds simple, but took a bunch of time to figure out. I didn’t build this car originally, and don’t have a lot of information available on the parts used. There’s a lot of junkyard engineering here. Not bad, just unknown what it came from.
    For a manual, I need a clutch pedal. There’s not a lot of room in the footwell. When I got the car, it had one of those big rectangular GM power disc brakes pedals in it. I cut that down, and swapped on a smaller Camaro pedal pad with its stainless trim.
    So there is now some room. Not a lot.
    The challenge here is that I don’t know what this pedal ***embly came from. I don’t want to change the brake pedal, that would require reworking the brakes. A trip over to my local muscle cars parts place showed that this is not a muscle car pedal, they are all much shorter. So I spent a lot of time looking at eBay and various forums to find pictures of pedal ***emblies.
    Eventually I came to the conclusion that this pedal ***embly is late 70s to early 80s square body truck (Blazer, etc.). I found a local guy with a late 70s Blazer and it matched up.
    Talked over the project with American Powertrain at their booth at Power Tour 2026. Found that they have a hydraulic clutch pedal setup for these trucks, as a retrofit. They don’t know if it will work for me, but it’s a good place to start.
    I blocked up the master cylinder and removed the brake pedal ***embly.
    The original manual trucks had a different stamped hanger, with some additional support, and room for the third pedal. The automatics, like mine, don’t have room for the pedal where it needs to fit. But a few minutes with a cutoff wheel solves that problem.
    Here is the new pedal temporarily mounted on the hanger, with the brake pedal. Also shows the 1/4” steel adapter that attaches the hanger to the underside of the dashboard.
    All of this won’t go in to position, the column is in the way. It has to be ***embled in place. Hanger goes in, then build the rest on it. I was very happy to find that the back end of the hydraulic cylinder clears the fuse panel.
    The pedal spacing is probably great for a truck. Not so much for a 37 Chevy.
    Made a new pedal pad from 1/8” steel, and picked up another matching rubber pad and stainless trim from my local muscle car parts place.
    Cut off the pedal pad. Can’t return the parts now that I’ve started modifying them. I borrowed a press from a friend, and straightened out that dogleg at the bottom. That makes the pedal arm too long, but I have a grinder and cutoff wheels.
    Welded on my new pad.
    Re***embled everything under the dash again.
    With the pedals back in, this is very drivable. I spent some time driving around and pretending to have a manual, to get used to the position of the clutch pedal. My DD is a manual, and has been for 30+ years, so I don’t need to learn to drive a manual, but I do need to get used to this car. Should work out ok, I think.
    So I ordered the rest of the parts I’m going to need.
  2. David Gersic
    David Gersic
    from DeKalb, IL
    Time p***es, a few hundred pounds of boxes get delivered to my driveway .
    I bought an ATV jack off of some guy on FBM. Some dis***embly of things later, the 700R4 is on the floor. Also removed the trans cooler, janky cooler lines, and the electrical and vacuum lines needed to run the lockup converter.
    Unboxed the new TKX and temporarily installed the shift lever. The directions want me to check to make sure it shifts in to all six gears before installing it. It does.
    They sent it with their “mid shift” conversion. This mounts the shifter as far forward as possible.
    Notice that the 700R4 has a Lokar floor shifter on it. I already have a hole in the floor pan.
    scotty t likes this.
  3. David Gersic
    David Gersic
    from DeKalb, IL
    168 tooth flywheel installed.
    Checking bell housing runout. I made a dial indicator mount to get it in the hole, using a HF magnet and some bits of steel.
    It’s a pain to turn the engine from the front while trying to watch the dial indicator on the back. So I mounted my phone to a jack stand, and used my iPad to view it via FaceTime. Now I can turn the engine and watch to line up the dial indicator.
    Horizontal is perfect. Vertical is close enough. No offset pins needed.
    Clutch installed. I did this part a few times. Just having the plastic alignment tool isn’t enough. The clutch really needs to be pretty close to perfectly aligned with the bearing in the back of the crankshaft.
    Installing the release bearing on the trans. This is temporary. It won’t fit in to the bell housing like this, and has to be ***embled in place as you insert the transmission. The hydraulic lines go out the clutch fork hole.
  4. David Gersic
    David Gersic
    from DeKalb, IL
    With a custom wood block, lifting the new transmission in to place on the ATV jack. I had to remove the shifter for floor pan clearance as I got the trans into position. Lifting the trans, lining it up with the bell housing, clutch splines, release bearing, and crank shaft bearing is a pain in the ****, but I got it all in there eventually. It did take a few tries, and not a little swearing.
    Pleasant surprise, the crossmember fits right back where it was. I was expecting to have to move or modify it.
    Even better surprise, the shift tower pops up right in the old floor shifter hole. Minor t******* needed to get access to the bolts to reinstall the tower, but it fits.
    Mounting the reservoir for the new clutch master. There was already a hole in the firewall here, I don’t know what it was for, it had a rubber plug in it. It was too small, so I punched it out to a larger size and put a grommet in it before routing the supply line to the clutch pedal under the dash.
    It’s a little too billet pretty. I may try to tone that down, maybe engine turn it. We’ll see.
    Needed a new starter. The bell housing doesn’t fit the old style of GM starters. Local “starters and alternators” shop hooked me up with this geared starter.
    Driveshaft installed. I mistakenly ordered it with a 1330 U joint, needed a 3R to mate to the diff. So I had to get a conversion U joint from NAPA. 1330 on one side, 3R on the other.
    While I was working under the dash, routing the hydraulic lines, I wasn’t happy with the wiring to the column. I chopped off about 8” of wire, re-worked the harness, and installed new connector plugs and pins for the column. Cleaned up the routing. Also sewed up a quick little black vinyl and Velcro cover for the bottom of the column to hide the harness routing.
    Last piece installed, the shift knob.
  5. lumpy 63
    lumpy 63
    You will love it. Had a tko in my 37 and have a tkx in my Camaro. tkx does shift a lot better from 2nd to 3rd
    scotty t and David Gersic like this.
  6. pprather
    pprather
    Nice conversion and good tech writeup.
    klleetrucking and David Gersic like this.
  7. Scott Danforth
    Scott Danforth
    Great work, great writeup.
    David Gersic likes this.
  8. guthriesmith
    guthriesmith
    Very cool! I am fixing to do similar to my 56 if I can ever get back to work on it.
    David Gersic and TrailerTrashToo like this.
  9. 6sally6
    6sally6
    Hard to beat 'rowing-thru-the-gearz' .......(unless you live in Atlanta) !!
    Enjoy...Nice write up
    6sally6
  10. RodStRace
    RodStRace
    Thanks for the detailed writeup! It's not something I plan on, but the ***le made me think someone wanted a list of what to do, not share How It's Done! :D
  11. rockable
    rockable
    Great job! Tech write ups like this used to be common on the HAMB. I wish they still were.
    SS327, David Gersic and Ned Ludd like this.
  12. I love the Facetime ingenuity. Also I would say this belongs in the on-topic forum but what do i know?
    Great write up.
  13. David Gersic
    David Gersic
    from DeKalb, IL
    I’ve been sick all week, haven’t accomplished much of anything. Got a few more things to add to this thread. Some may seem obvious, if you’ve done this before. I haven’t. Maybe they’ll help the next guy.
    Lessons Learned
    This setup uses a pilot bearing. This supports the front of the transmission input shaft when the clutch is released. Older transmissions used a pilot bushing. The kit included the new bearing, and the directions recommend using the “grease” method of removing the old bushing from the crankshaft. I spent an embarr***ing amount of time on “removing the bushing”, because this engine was from an automatic equipped car. Automatic engine crankshafts didn’t get a bushing, because the flexplate and torque converter are always firmly attached to the crankshaft.
    The pilot bearing installation instructions say to drive it “flush” with the crankshaft. To me, “flush” means something other than what it means to the guy that writes the directions. He means driving it in to the crank until it bottoms out. I did not have it all the way in, which prevents the transmission from being able to fully seat. Removed and reinstalled the transmission a few times before figuring this out.
    Once the pilot bearing is in, installing the clutch on the flywheel includes one of those plastic alignment tools. The plastic is flexible, where the steel input shaft of the transmission is not. Not only do you need the plastic tool to go in to the pilot bearing and clutch splines, you need to get the clutch in position so that the alignment tool goes in and out as easily as possible. A steel tool really would be better here, though plastic is clearly less expensive. The better you do with this alignment, the less effort you have to put in to getting the transmission aligned just right so that the input shaft goes through the splines and in to the pilot bearing. Learning this required a few remove and reinstall the transmission cycles, as not being able to line it up means you can’t get it all the way in.
    Yes, the ATV jack got a lot of use.
    I am surprised that I needed a “race car” starter. The supplied bell housing does not fit any starter with a nose cone. We tried every starter at the local “starter and alternator” rebuilder shop. They were surprised too. It may be worth finding out if there is a bell housing that will fit an SBC on the front, whatever the TKX mounting is on the back, and takes some kind of normal GM nose cone starter. Hacking at it with a grinder may also work, for the adventurous. There was one starter that almost fit, and I was tempted to make it fit with some grinding, but I didn’t go down that path.
  14. David Gersic
    David Gersic
    from DeKalb, IL
    Initial testing. I pushed the car out to the driveway for this. The “mid shift” setup precludes a Neutral Safety Switch. I could wire one in to the clutch pedal, but I did not. Like an old car, I can engage the starter with the car in gear, though I have no intention of ever doing so.
    They recommend first start with the transmission in neutral, brake and clutch pedals both engaged. Did that. Engine started. I let off the clutch pedal, nothing happened, and I let the engine warm up before continuing.
    They recommend testing First, and Reverse, then a test drive to try out the other gears. I did that too.
    Problems to be Resolved
    The speedometer doesn’t work. Probably an easy fix. I have a 90* adapter installed to keep the cable away from the exhaust. I need to flip the adapter around so that it rotates the cable the other direction.
    There is some driveline vibration. The angles are off. I ordered some shims to change the pinion angle, which should help.
    It feels like the clutch isn’t fully releasing. With the pedal all the way to the floor, if I put the transmission in first, it will start to creep forward. It’s pretty hard to shift, seems like it should be easier, which is a symptom of the clutch not releasing. Also, when lifting my foot, as soon as it starts to move, the clutch is engaged and away we go. I don’t yet know how this will be resolved, but I have some ideas.
    pprather and RodStRace like this.
  15. RodStRace
    RodStRace
    I agree, flush is not fully seated!
    You have a full bellhousing, which will make this more difficult, but there should be a measured gap when clutch is depressed at the plate. Check this out. It should be in the instructions or thru the retailer.
    I have not cared for hyd releases for this reason. any little thing means pull it all apart.
    Again, there should be a measurement for fully retracted and fully extended from the people that sold this. They have various means to set these, get all the info. Also, they do not bleed like brakes. You must get all the air out, which often means vacuum or pressure bleeding.
    A number of kits to fit muscle cars tend to 'droop' the trans because it's bigger than the stock trans and will not clear the stock floor. This shouldn't apply here.
    If the tailshaft is the same relative height in the car, this should not have induced a new vibration, even if the driveshaft is a little shorter.
    Good luck ironing out the last wrinkles!
    SS327 and David Gersic like this.
  16. Scott Danforth
    Scott Danforth
    for an HTOB, I thought the magic distance to measure was 0.2" or 5mm of clearance between the pressure plate fingers and the bearing on a fully retracted HTOB. At least that is the dimension I remember from the last few HTOB setups. measure mounting flange of bellhousing to fingers. subtract HTOB measurement from bearing face to trans face. dimension must be 0.2". shim HTOB as required.
    confirmed per https://americanpowertrain.com/heil-hydramax-setting-up-your-hydraulic-release-bearing/
  17. David Gersic
    David Gersic
    from DeKalb, IL
    Yeah, did that. They specify 0.150”, +/- 0.05” as the air gap when released. Your 0.200” is at the outside edge of what should work.
    I measured bellhousing to clutch fingers at 2.737”, and bearing face to transmission at 2.493”. That gives me an un-shimmed air gap of 0.244”. The supplied shims claimed to be 0.09” each. I installed one shim, for a supposed air gap of 0.154”, almost perfect for the spec of 0.150”.
    Yesterday, measuring the shims directly, I got about 0.077” effective thickness. These are 45* cones and it is kinda hard to measure a stack of them, so that may be off a little. But 0.077” is not 0.090”.
    I measured actual thickness of the shim material at 0.057”. With some geometry, that makes each shim 0.080” effective vertical thickness, very close to my measured 0.077”, and definitely not 0.090”.
    The difference between 0.09” and 0.08” isn’t enough to matter, I think. That may mean that my supposed 0.154” air gap is actually 0.164”, still well within spec. But things out of tolerance tend to stack up to the point where maybe it does. I also don’t know right now if I’m getting a full stroke on the clutch pedal before it hits the floor. I’m sure it worked fine in the truck it was designed for, but I need to double check that too. Less than a full stroke, a slightly under-thickness shim, maybe an error in measurement, and pretty soon things add up.
    If I can kick this head cold so my brain stops hurting, I’ll crawl back under and get it figured out.
  18. David Gersic
    David Gersic
    from DeKalb, IL
    I thought I had it sufficiently bled. I could be wrong. It’s easier to bleed it some more than to pull the trans again, so yeah, I’ll be looking at that first.
    I think the tail is in about the same place as the old transmission. But I didn’t measure the angles on the old one before removing it. I probably should have. I guess that’s another lesson learned.
    At the tail shaft, I have 5.1* down. At the pinion yoke, I have 1.7* up. That is far enough off to induce vibration, whether it had it before or not. I have some 3* shims to install.
    RodStRace likes this.
  19. Scott Danforth
    Scott Danforth
    Use a vacuum bleeder
