1952-59 Ford Automatic to manual transmission swap question
Discussion in 'Off Topic Hot Rods & Customs' started by Mark T, Mar 26, 2023.
  1. Mark T
    Mark T
    Are the bolt holes in the frame to mount the Z bar, if so are they already threaded?
  2. 57Custom300
    57Custom300
    from Arizona
    I did that conversion on 3 Ford cars over the years. 56 Ford, 69 Mustang and my current 61 Starliner. All 3 had the mounting lugs already in the frame. Covered with grease but they were there.
  3. Mark T
    Mark T
    Thank you…
  4. Paul2748
    Paul2748
    My 54, originally automatic, had the threaded bolt holes in the frame.
  5. Mark T
    Mark T
    Thank you.
  6. brushwolf
    brushwolf
    My 61 Sunliner had the holes but no threads. Had to cut the frame on a scrapped 61 Fairlane to get the weld nuts to put in there. I have done quite a few 50's Ford swaps also and they were always there until this one. 73 Mustang had them too. Maybe they just forgot to put them in this 61..
  7. Mark T
    Mark T
    Thank you.
  8. guthriesmith
    guthriesmith
    Assuming you are doing this to your 55? I keep considering the same on my 56...
  9. ffr1222k
    ffr1222k
    I just did my 56 but used a T5 transmission. The 5.0 bell housing had no provisions for clutch linkage other than for a cable so I used a cable.
  10. Mark T
    Mark T
    Yes, I recently changed directions and decided on using a manual transmission.
  11. mikhett
    mikhett
    from jackson nj
    Good Choice!
  12. 51504bat
    51504bat
    Make sure you put in a pilot bushing/bearing. Don't ask me how I know.
  13. Mark T
    Mark T
