**Automatic tranny options for a 235?**
Discussion in 'The Hokey Ass Message Board' started by Big Dirty, Dec 16, 2007.
  1. Big Dirty
    Big Dirty
    HAMB'ers!!
    As the ***le reads I'm searching for Auto ****** options available for the 235 in my Suburban.
    My girl can't drive a stick (easy you dirtbags!!!) and since I want to change to an open driveline I need some ideas.
    Thanks for the input!!
    Dirty
  2. rumblytruck
    rumblytruck
    There's an adapter out there to put a 700r4 behind your inliner, gimme a few minutes and maybe I can remember who.
  3. Big Dirty
    Big Dirty
  4. squirrel
    In the 50s you could get a 4 speed automatic Hydramatic trans in trucks behind a 235. These are not overdrive transmissions (the 700 is overdrive), and they're hard to find and not too easy to get parts or someone who knows how to work on them. Also in the 50s you could get the powerglide behind a 235 in cars, this is a 2 speed trans, pretty easy to find, but also difficult to get parts and someone to build one.
    The "modern" transmissions like the TH350 and 700R4 require a kind of expensive adapter to put on a 235.
    Might see if it would be easier to find a newer 6 that will bolt right up to the modern transmissions...although you'd loose the cool factor of the early engine.
  5. Joe King
    Joe King
    vrrrroommmmmmmmmmmm vrooommmmmmmmmmmmmmmmm
    power glide
  6. rumblytruck
    rumblytruck
  7. A31Slant
    A31Slant
    Langdon's stovebolt sells an automatic transmission adapter for $350.00. You could also use a 200r4 trans.This would give you overdrive. I'm installing a chevy s10 4x4 10 bolt rear in my '50 chevy. The s10 4x4 blazer and truck rears are 60" wide just like the '49-'54 chevy cars. I picked my rear up for under 100.00 bucks.
  8. 55 dude
    55 dude
    buffalo enterprises sells one also. $350 i think is the cheapest one i have seen. i have driven a 51' panel with 235/350 turbo and at 90hp kinda like a chevette!
  9. Big Dirty
    Big Dirty
    Thanks guys for the input. Is there a paticular year 700R4 I would have to run or does it matter?
    Dirty
  10. 53sled
    53sled
    from KCMO
    earlier ones have less computer controls, but you need a lockup switch, like the b+m kit, and the tv cable must be adjusted properly.. its not a kickdown cable.. look for bowtie overdrives, they may have a nice setup for you.
  11. Mist Green 50
    Mist Green 50
    from New Mexico
    why not teach the ole lady how drive stick?Problem solved.
  12. squirrel
    The newer the better, but make sure it's not newer than 92 when they went to computer control. Non computer ones have a 4 pin conector on top of the pan area, and maybe a wire connector at the speedo gear area. Computer ones have a ****load of wires.
