Technical automatic tranny
Discussion in 'The Hokey Ass Message Board' started by 0nedon, Aug 3, 2021.
  1. 0nedon
    0nedon
    I'm 70 and never saw a G.M. automatic transmisson that was air cooled. Older than me buddy showed me an automatic ******, 60's he said that was air cooled, he even has the 6 cly. it came with out of, pick up if I remember right. It had no lines to run to a cooler or rad. and it had 2 factory holes in the houseing about 2" dia.. He said it did hold fluid but no cooler lines . He was courious if anybody else had any info? Thanks for any info.
  2. 40Standard
    40Standard
    from Indy
    powerglide?
    loudbang, mgtstumpy and Hnstray like this.
  3. 1934coupe
    1934coupe
    Yeah I had one in my 36 Willys sedan, came out of a Nova only mine was a 4 cylinder trans was a air cooled PG. Motor ran good and trans was great, they do tend to get a little warm and sometimes the engine would stumble but it never seemed to be a problem.
    Pat
    loudbang, mgtstumpy and 2OLD2FAST like this.
  4. Hnstray
    Hnstray
    from Quincy, IL
    Yes, Aluminum Powerglide (1962 origin) used with 4 cyl and 6 cyl models and also a later variant called Torque Drive (non-self shifting PG). Converter has fins added and 4 holes in belled area of trans case for ventilation.
    However, not a new idea when introduced. Early Ford O Matic (Borg Warner) designs also used air cooled converters. Perhaps others too, don’t have any info on that.
    Ray
  5. mgtstumpy
    mgtstumpy
    An old air-cooled Powerglide from a Chevy van. Google indicates that the air cooled 4&6 cyc 'Glides still had the inlet and outlet ports however they used a different pump and had a different 1st gear.
    loudbang and anthony myrick like this.
  6. squirrel
    lots of air cooled automatics over the year....Ford and Mopar in the 50s, Chevy in the 60s. Chevy of course did it cheap and simple, they just drilled 4 holes. The others used fancy ducting on the bellhousing.
  7. goldenidolcustoms
    goldenidolcustoms
    from Pa.
    C
    cadillacs were air cooled until 1956
  8. 302GMC
    302GMC
    from Idaho
    '40 up single & dual range hydros ...
    mgtstumpy likes this.
  9. 0nedon
    0nedon
    Thanks for all the info. guys. I sure didn't know that many were around
  10. junkyardjeff
    junkyardjeff
    Is it me of did those older air cooled trans seem to last longer then the newer fluid cooled versions.
  11. squirrel
    they made them back when engines had 100 hp, not 300
    Hnstray and Sporty45 like this.
  12. jimmy six
    jimmy six
    Mine is a combo. The trans was a water cooled and was installed where there was an air cooled. With some work the air cooled torque converter was retained because the shop lacked all the conversion parts. Works great.
  13. Chrysler PowerFlite too.
