Automatic trans (325-4L) question
Discussion in 'The Hokey Ass Message Board' started by Animal, Jul 17, 2011.
  1. Animal
    Animal
    I need some advice....I'm using a 325-4L transaxle in an OT project, and I'm using a GPS speedo. Can I totally eminate the speedo drive and just cover the hole, or will that cause a problem with trans fluid flow patterns? Anything else I need to consider? I'd appreciate any help I can get!:D
  2. Animal
    Animal
    Any auto trans gurus out there?
  3. 1930 A
    1930 A
    If I remember correctly the speedometer for the trans is part of the governor ***embly so no you can't run it without that housing. No reason you can't just leave the speedo cable disconnected though.
  4. Animal
    Animal
    That's the kind of info I was looking for....thanks a lot for taking the time to respond. :)
