Technical Automatic trans with B&M Shifter Question
Discussion in 'Traditional Hot Rods' started by Ehlien, Sep 24, 2016.
  1. Ehlien
    Ehlien
    I put a 350 auto hooked to a 350 Chevy in my car with a B&M slap stick shifter. My question is about the kick down linkage/function. Do I hook it up or just forget about it for this application?
    Thanks for your feedback.
  2. Jerrybigbird
    Jerrybigbird
    from Montana
    If it was me id hook it up
  3. If you don't hook it up you will have to Manuel shift it every gear. If this is what you want to do then you should put an m22 rock-crusher trans in it. Go with a 4 speed with a pool ball shifter or hook that kick down up...
  4. Ehlien
    Ehlien
    Ive been reading a lot of posts that say for a 350 its not necessary to hook it up especially if its a very light ride and that it will up shift automatically (but probably quicker than usual) but you will need to shift down manually to compensate for the eliminated kickdown function. There were many guys not running the cable as well as a few saying they recommended still using it so it sounds like it will function either way. For overdrive transmissions it was mandatory to have one and it be properly adjusted or trans failure is eminent..
  5. Hook it up, give your ****** every possible benefit of a long life.
  6. Why would you not hook it up?
    Max Gearhead likes this.
  7. falcongeorge
    falcongeorge
    from BC
    ???Whaaaaa?:confused:
    gimpyshotrods likes this.
  8. squirrel
    TH350 has a kickdown linkage, not a Throttle Valve linkage. You can run it without the kickdown cable connected, it will shift early and soft under full throttle conditions, compared to if you have the kickdown.
    Do whatever you want...it'll work either way, it will work better and last a long time if you do it right and connect the cable.
  9. 56sedandelivery
    56sedandelivery
    The TH350's sold by JEGS and SUMMIT, with their name attached, come without the kickdown cable feature. In fact, the hole in the trans rail for the cable is PLUGGED. "Most" guys who delete the kickdown cable have also installed a shift kit, and that somewhat makes up for anything lost by deleting the cable.
    I am Butch/56sedandelivery.
