Technical Av8 48 f1 steering box
Discussion in 'Traditional Hot Rods' started by 30ccpu, Jan 27, 2016.
  1. 30ccpu
    30ccpu
    Hi I've picked up a 48 f1 steering box for my av8 and was wondering if anyone has pics for fitting to the a Ch***is and mods to the steering box mount flange thanks.
  2. F 100? or F 1? are you sure of the year?
  3. crminal
    crminal
    There are so many existing threads to mention. I just searched "f-1 steering" in general discussion and found a bunch of threads. Good luck
  4. cadillacoffin
    cadillacoffin
    do a search for AV8 also. alot of well do***ented builds.
  5. alchemy
    alchemy
    48-52 is an F1, and 53 on up is F100. If your box has a big nut on the end of the sector holding the pitman arm on, it's an F1. If it has a pinch bolt holding the pitman arm on then it's an F100.
    Prewar likes this.
  6. Kiwi 4d
    Kiwi 4d
    Also the 48 to 52 F1 steering box has the steering shaft at the bottom of the box and 53 to 56 F-100 had the shaft at the top of the box either could be better for certain applications. Both mount to the frame the same way. If it's had water in it be wary of the bottom bearing land getting pitted.
    Vern Tardel has a great little book "ford steering" on how to fit a effy box to a hot rod.
  7. The guy the model A guys go to is Randy Gross. Even though you don't have a stock Model A you might contact him and see if he can help. Email melmodela@aol.com or phone 714-292-8660.
    Charlie Stephens
  8. 30ccpu
    30ccpu
    Thanks for the info. Sorry it's f1 has big nut on sector shaft holding pitman arm and steering start at bottom of box. I'll have a look in some of the build threads for pics.
