Projects AV8 combo help.
Discussion in 'Traditional Hot Rods' started by Hot Rod 50, Jan 5, 2016.
  1. Hot Rod 50
    Hot Rod 50
    1930 ford coupe. Gathering parts to eventually go Av8. So far I have a V8 radiator 50 merc flathead 35 ford trans and bell housing adapter. My plan is to use the stock A banjo. So my question is what pedal cluster should I look for, for the clutch and brakes.
    Or, since I MAY, stay with the mechanical brakes how could I make the stock A clutch pedal work. I'm not dead set on the mech brakes. I know there's lots of reasons to go juice. As of now I have the banger running, installed the flathead teds kit and just need to drive it to see how they work. Then I'll decide.
    As far as the motor, it will be just a little warmer than stock with 2 94's. I also know the deficiencies of the A banjo but thats the direction I'm going.
    Thanks.
  2. Hitchhiker
    Hitchhiker
    why not use the pedal bracket used on the v8 transmission to 4 banger kit. That would use the stock pedals.
    for me what pedals I use is directly related to the transmission crossmember
  3. Hot Rod 50
    Hot Rod 50
    Ok. Is that a "kit" like from speedway or should I just find a 35 crossmember and make it all work?
  4. Hitchhiker
    Hitchhiker
  5. Model A Gomez
    Model A Gomez
    Sacramento Vintage Ford sells the kit too. Consists of a pedal mount bracket that bolts to the trans and uses stock pedals and a mount for the stock un-split wishbone. puts the pedals in the stock position, I used it on my avatar a 28 with an early flathead, a 30 pickup with a B motor and V8 trans and my 30 Sport Coupe with an 8BA flathead.
  6. Jalopy Joker
    Jalopy Joker
    post pics of project
  7. Hot Rod 50
    Hot Rod 50
  8. Hot Rod 50
    Hot Rod 50
    Clings is perfect. I had sticker shock when I looked at the kit as a whole at it was $400 big ones. Then figured out you said he sells the pieces. Mas Bueno. Couple hundred and I'll be in business.
    Thanks again. Gotta love the hamb.
