Technical AV8 is UNSTABLE Any ideas?
Discussion in 'The Hokey Ass Message Board' started by highboy, Apr 2, 2014.
  1. highboy
    highboy
    from marin
    So let me start with a little history of this car. I built it in 99 got it on the road and got all the bugs out by 2000. It has always been dependable and fast. I've driven it to Bonneville and Vegas several times going speeds over 80 for long stretches comfortably. Last year driving up to Tahoe i hit some bumps on 80 east and the rear end felt loose slowed down made it home safe gave it an inspection found my rear panard bar bracket loose and thought that must have been it.. But it wasnt .. didn't improve Actually since last summer it has gotten more unstable as time goes on. Which leads me to think something is worn or has failed. With every inspection i find a small thing to fix but never THE thing.
    The best way to describe the problem is if something sends the car up, when it comes down it's anybody's guess where she'll go.And with the condition of these freeways thats a scary deal. Lets cross some of the obvious off the list. Caster and Camber? good.. checked multiple times. Rearend location? Parallel to front i beam and centered in frame and no movement. Drag link? solid. Tie rod ends? good. I am considering king pin and bushing ware. But again when i shake the tires i dont see any movement there either. Tires? swapped all four and didnt change a thing am I forgetting anything obvious? Any help would greatly be appreciated...
  2. Long shot. ... cracked frame. Flexing when under load. It will feel like the rear end has a mind of its own.
  3. harpo1313
    harpo1313
    from wareham,ma
    Have you inspected the frame itelf?
  4. Daddy_O
    Daddy_O
    You didn't describe your front axle setup. Do you have a panhard bar to the frame on the front end?
  5. Borrow a set of tires & wheels from another car and see how it drives with them on. I suspect you broke a belt on one or more tires when you hit whatever it was.
    Come to the darkside and run radials...
  6. hotrod40coupe
    hotrod40coupe
    I didn't see shocks listed in the "OBVIOUS".
  7. highboy
    highboy
    from marin
    Bad rear shock? would that affect my tracking? I've poked and pried on all cross members. nothing there, swapped all four tires again no help. dont see any cracks in frame..front panard is solid...
  8. Dirty Dug
    Dirty Dug
    It could if one has gone bad completely.
  9. tjet
    tjet
    1. Early Hemi Tech
    A bad shock wont change the steering feel / direction. It will just keep bouncing. I would agree with a crack in the frame. You are describing a bump-steer situation.
    Can you remove the springs so you can simulate the suspension travel - like while on jacks or something?
  10. highboy
    highboy
    from marin
    Okay well that's on the top of the list for Sat morning...stupid job. They pay me just enough to keep coming back on Monday
  11. ROADSTER1927
    ROADSTER1927
    By the way unless your king pins are about fall out, you can not check by moving the tires. You need to jack it up and watch for movement. I agree with the tires and possible cracked frame. Gary
  12. highboy
    highboy
    from marin
    Well as it turns out there's a local parking lot with a large sway in it for drainage and when i cross it even at low speed 5mph it'll do it i just need an outside set of eyes to help
  13. My money's on a broken bead in a tire. When you switched the tires around did you go front to rear on the same side? Sometimes it's not easy to see tire tread separation with the eyes. Let the air out of each tire and "read" the tread pattern. If that doesn't show it ...try over inflating... a bit and look for a distortion in the tread pattern. Don't blow the tire off of the rim though!! A major malfunction, like a cracked or broken component, would be easy to locate. I don't think that's what's happening here. It's the little stuff that's hard to find.
  14. tjet
    tjet
    1. Early Hemi Tech
    If you have one of those Go-Pro cameras, you could zip-tie it to the frame to record what the tires are doing.
    Even tho this car in the video below is not hamb friendly, it give you an idea of the major forces involved during suspension movement
    https://www.youtube.com/watch?v=FIFZMa1pyX0
  15. highboy
    highboy
    from marin
    I didn't switch the tires around. i put on an entirely different set of wheels and tires. Again no improvement.
  16. highboy
    highboy
    from marin
    Watched the youtube clip and it was eye opening. I'm running a solid rear axle but i'm sure those same laws apply.
  17. McGurk
    McGurk
    from Mid West
    Do you have a mixture of bias ply and radial tires?
  18. highboy
    highboy
    from marin
    What am I? A crazy person? :eek: hehe... No. Bias plys all the way around.
  19. greybeard360
    greybeard360
    What is the supension setup on this car? I am having a hard time wrapping my head around your description of what the car is doing exactly.... "if something sends the car up, when it comes down it's anybody's guess where she'll go"...
    Are you talking about when the suspension is traveling up, then down it gets squirrely?
    You mentioned the rear end felt loose..... how about the shocks. If one is dampening and the other one isn't (both at same end of the car) it can make a car feel "loose" and can make it want to change directions on you. You also mentioned hitting some bumps just before it started this.. look at the shocks close... any bent? Pull them off and compress and extend them... do they work the same? A bent shock could be binding up and stopping in its travel on compression (down stroke) yet extend out fine on rebound stroke.
    Leaf springs?? Look close at the leaves along their length.... may have a broken one causing one side to be weaker than the other.
    Did you check toe in? Could have bent the tie rod tube changing that.
    Need mo info !!
  20. highboy
    highboy
    from marin
    This is whats baffling me it all looks good. I've even had a couple of guys who know tons more than I do a walk around cant seem to locate it. I guess this weekend I'm gonna put her up on a lift. check the frame for any cracks check the front leaf spring pack and the shocks as well. Thanks for all the input. I do appreciate it. Hopefully I'll find something. Keep you posted
  21. gimpyshotrods
    gimpyshotrods
    Pull the shocks out and bench test them.
  22. ironfly28
    ironfly28
    from Orange, CA
    check your leafs in your spring pack...my $.02... are you running friction/ oil shocks? if you busted one of those just right it could be like having a solid rod between your frame and axle...you wouldn't have to pull them to know, just go push down on your rear quarters.
  23. hotrod40coupe
    hotrod40coupe
    I once had a '36 pickup with bad shocks that would swap ends on a rough road. If shocks weren't important, Detroit wouldn't put them on cars in the first place.
  24. Happydaze
    Happydaze
    Steering box mount cracked or something allowing flex? And another vote for checking the toe in.
    In the UK as part of the annual inspection (pre 60 cars became exempt a couple of years ago tho) someone sits in the drivers seat and 'rocks' the steering wheel while the examiner is underneath inspecting all the components and mounts for play / flex etc. ie it's a two man job to do the inspection. So that's a second use of the fairer sex. The first? Operating the pedal while brake bleeding
    Chris
  25. tejays
    tejays
    from australia
    Maybe broken eye bolt.
  26. tim b.
    tim b.
    Bump when it occured could have been just a coincidence. What are you running for a center carrier. If its a Posi or limited slip could be you've got a clutch/spring engagement issue.
  27. 56premiere
    56premiere
    Possibly broken spring centering bolt , allowing small amount of movement of rear axle.?
  28. GlenC
    GlenC
    I snapped the end clean off a rear shock on a highway run one day, hit a big bulge in the concrete. Next thing I know the rear driver's side of the car is bouncing around like a ball every time I hit a small bump.
    Up she'd go, way up, the down, and bounce, bounce, bounce, we went, down the highway. Kids in the back seat thought it was funny, I was fighting to keep the car on the highway, it was going all over the place! Every time the rear went up, the front on the opposite side would nose dive, bump steering the car all over the road. (4 wheel independent suspension)
    I had to slow right down and we crawled into a service station where I unbolted the broken shock and got the mechanic to weld the end back on. Once that was fixed, she was back to her usual self on the road.
    Good luck with the fix,
    Glen.
  29. oldtom69
    oldtom69
    from grandin nd
    are we talking about traditional cross spring front and rear?If so, after you have tried everything else,remove[or at least disconnect 1 end]of your front and rear panhard bars.If it does'nt cure it,hook them back up,your not out much time.If it does work let us know and I'll explain why,but I'm too tired today to spend hours explaining why it can't possibly be the problem.try it
  30. captain scarlet
    captain scarlet
    from Detroit
    When you check that look at the hair pin mounts at the frame, and all the spring shackles
    Martyn
