Technical AV8 Late Model Banjo Spring Over Conversion
Discussion in 'Traditional Hot Rods' started by Haven Hills Auto Club, Apr 14, 2020.
  1. italianhotrodder
    italianhotrodder
    from sweden
    i have same setup but with a T rear spring made by oldyankee for model A and 1937-1940 rear axle i'm using the original spring perch , but the frame touch the axle , which spring do you have ?
  2. Stock Model A with 5 leafs.
  3. italianhotrodder
    italianhotrodder
    from sweden
    and model A cross member? thanks
  4. joel
    joel
    FYI. Ford banjo rear ends wear on the bottom side of the axle housing bearing race extension. You should mic the O.D of that for wear. You may need to have that repaired, which could be done at the same time the housing is shortened. PM sent.
    italianhotrodder likes this.
  5. RICH B
    RICH B
    You can also flip the housings so the worn and sometimes pitted bottom is on the top.
