AV8 motor mount cross member in the way
Discussion in 'The Hokey Ass Message Board' started by bloodyjack, Sep 20, 2008.
  1. Bruce Lancaster
    Bruce Lancaster
    And, if the car is being built with early drivetrain on stock axis, like '39 trans and A rear, you don't want to adjust height by arbitrary dimensions. Transmission bolted to torque tube and crossmember set rear height on Model A axis, center of front pulley height can be set to stock axis by aligning it with hand-crank bearing on front crossmember.
  2. bloodyjack
    bloodyjack
    Height needs to be the same but I am useing a T5 transmission. I have one from a 4x4 so that I can still use a torque tube and hide this indiscretion
    Dug do you have a old flywheel lying around? I need one and cant afford a new one. The picture is just a mock up no clutch or flywheel yet!
  3. Nobodys Hero
    Nobodys Hero
    from New Jersey
    you shouldnt be using a t5 out of a 4x4.
