Technical AV8 rear brake question
Discussion in 'Traditional Hot Rods' started by T Hudson, Dec 11, 2017.
  1. T Hudson
    T Hudson
    My buddy is doing an AV8 ch***is for a '27 T. He is using a '40 Ford rear axle and has '52 F1 rear brakes. It seems to him, and I recall this also, Tardel's book claimed this was a bolt on. It doesn't appear to be, can anyone sheds some light on this for him? He is a BC guy (before computer) and asked me to put this out. Thanks!
  2. RICH B
    RICH B
    Not even close. F-1 front brakes will fit on the front tho.
  3. Fred A
    Fred A
    from Encino, CA
    F1 fronts can be made to work on the early front axle, not quite bolt-ons. Buy the book. Good Luck Fred A
  4. 55styleliner
    55styleliner
    Yep, not going to work. Use the 40-46 brakes or buy the brake kit from Speedway.
  5. e z i
    e z i
    IMAG0756.jpg I used f1 brakes on the rear of my model a cause I had them, but I had to cut the centers out of a set of 1940 backing plates I had laying around, and mate them up to the f1 backing plates.
    It was a royal pain in the ***.
    I'd never do it again. I'll just use 40-48 rear brakes..
  6. RICH B
    RICH B
    What did you use for drums and what did you do to the early Ford hubs to adapt them?
  7. e z i
    e z i
    I used f1 drums, I machined/bored them out to fit the 40 hubs.
    RICH B likes this.
  8. T Hudson
    T Hudson
    We both own the book,
    See where it says, "The rears bolt on like they were made for old Ford axle housings" in the paragraph where it is talking about F1/100 brakes.
  9. Fred A
    Fred A
    from Encino, CA
    Without heroic re-configuration, the rears, including the ten inch drums and backing plates are not a direct bolt-on the '40 rear, but so many others including the '39-'48 rears, the Lincoln Zephyr hydraulic rears through '48 and many after market offerings as either Bendix, servo, self energizing, or wrongly '39 Lincoln are more easily made to work. Best Idea: Bolt away! Nothing is impossible to a great fabricator. Good Luck: Fred A
  10. chiro
    chiro
    Yes, that's not the only mistake in the book. There are others that are just as significant. The book is great, but there are a few mistakes.
    Andy
  11. RICH B
    RICH B
    As a non-heroic alternative, how about F-1 front brakes on a banjo rear. Maybe an hour to fab and weld in a couple e-brake cable tubes, any 11" brake hardware will work, and a small amount of machine work to reduce the flange and register diameters on the hubs. If you use Bronco drums instead of original F-1 drums (unobtanium) the lip will need to be faced off as it goes a little too deep. Simple hot rod fabrication (like in the old days).
    48fordnut likes this.
