Avanti starter problems
Discussion in 'The Hokey Ass Message Board' started by gbgh, Sep 11, 2012.
  1. gbgh
    gbgh
    So I buy this 63 Avanti! Car o' my dreams.
    Starts 9 times out of 10.
    10th try nothing.
    Arc the solenoid? It starts, for another 9 times, then same again!
    I get an arcing sound like a spark arc, but once it starts, smoooth as silk!
    Ideas?
    Yes I put in a new solenoid, and yes, same problem!!:confused:
  2. PackardV8
    PackardV8
    Congrats on owning a modern cl***ic.
    The ignition switches Stude used were junk. Replace the switch.
    jack vines
  3. Atwater Mike
    Atwater Mike
    Starting with battery, clean every terminal all the way up the cables. Lock washer all the 5/16" studs after cleaning, and examine terminals on cables. (!) Also the small wires: look for green acidic corrosion, replace any terminal where it shows up. (replace that wire if practical)
    Be thorough, and as PackardV8 states:
    Ignition and lamp switches Stude used were inferior. (known fact in the trade)
  4. gbgh
    gbgh
  5. aircap
    aircap
    Check over on the forum of the Studebaker Drivers Club website.
  6. tommy
    tommy
    Don't forget the ground cable and its connections It takes a good clean system on both sides to get a complete circuit. The juice needs to get back to the battery. Intermittent problems can be very hard to cure.
  7. lothiandon1940
    lothiandon1940
    ..........................So true.
  8. dtracy
    dtracy
    I know it's a bear to do but remove the starter and either test it yourself or have it tested. It could have a dead bar on the comutator. Makes an arcing sound and has intermittant open circuit.
    Dave.
  9. gimpyshotrods
    gimpyshotrods
