We Repurpose used Car Parts for useful Art Work. This Set is a One of a Kind Item. _The Table Lamp Shade was created using a Flywheel Ring Gear, which is Heat Blued and Clear Coated. Tig Welded to 22 guage Sheet Metal which has been Hand and Bead Rolled. The Sheet Metal has been left natural with a Clear Coat. The Stem is a Dana 60 Strange Racing Axel, Tig Welded to a Slotted and Drilled Rotor. The Stem is also Heat Blued and Clear Coated. Stands 28 3/4" tall with Base 11 1/2" round. Holds 2 light bulds. _The End Table has been created using a Slotted and Drilled Rotor, Tig Welded to a Dana 60 Strange Axel, Tig Welded onto a Slotted and Drilled Rotor. All are Heat Blued and Clear Coated. The Glass top is 3/8" thick, 16 3/4" x 32 1/2" Tempered. The End Table Stands 26 1/2" tall. _We will need your zip code to give an estimate for shipping.
