Technical Axle Shims ID & Leaf Spring questions
Discussion in 'The Hokey Ass Message Board' started by TAFreeman3, Sep 9, 2019.
  1. TAFreeman3
    TAFreeman3
    I’m working on my 1930 Plymouth model U, slowly dis***embling parts, blast, paint, re***emble. I’m working the front end right now and found shims between my leaf springs and the axle. I’m hoping someone can help ID them and school me up on them. Also Should I replace with new? (The second shim - not shown - is cracked in half and needs replacing)
    Second - when pulling apart the leaf springs, I removed the center bolt and can remove some of the leafs. A few of the leafs have clips held in with a rivet. Do I need to cut the river out to remove or is there some trick to pulls them apart ?
    Thanks in advanced !
    kidcampbell71 likes this.
  2. 302GMC
    302GMC
    from Idaho
    Used for setting caster and still available from Filling Station, Chevs of the '40s, etc.
    TAFreeman3 likes this.
  3. alchemy
    alchemy
    When the leaf springs were originally ***embled the U clips were riveted to that leaf, then the pack of leaves were ***embled with the center bolt. Last, the clips were bent around the whole pack.
    Maybe you can straighten the clips out to dis***emble? Maybe best to grind the rivet?
    For the shim, wait until you get the front end alignment done. They may want to use a wedge with a different angle to set proper caster.
  4. TAFreeman3
    TAFreeman3
  5. Joe H
    Joe H
    Heat the clip at the 90* bend close to the rivet and open it up. You can wiggle the other leafs out for cleaning. When going back together, squeeze it up tight with a c-clamp.
    If going back to stock, use the caster wedges it had in it, they will be really close to what it needs, big end towards rear of car.
