Technical Axle/Spindle Fitment Help, Please!!!!
Discussion in 'The Hokey Ass Message Board' started by brett4christ, Apr 11, 2017.
  1. You want to try to keep the tie rod holes on the same plane while dropping them so the cross bar will fit under the wishbones and keeping the same distance from the backing plate (which means the same length on the cross bar).
  2. subneil56
    subneil56
    from bristol vt
    what is the least amount turning radius you should have of the spindle after the bend is done ?
  3. brett4christ
    brett4christ
    Hey @subneil56, I do know that the nuts for the kingpin bolt double as steering stops, so I think you would want the spindles to swing until they touch these nuts/stops.
  4. Wooster
    Wooster
    from Soso, MS
    This is what I am doing. The tie rod hole in the steering arm is tapered from the bottom so had to taper it about half way through from the top I believe 7 degree.
