Customs Axle Swap Pinon Angle before Nailing it In
Discussion in 'The Hokey Ass Message Board' started by swaluda, Jul 4, 2015.
  1. swaluda
    swaluda
    from pa.
    just swapped a Ford 8.8 into my 1950 Plymouth. I have a set of ladder bars I installed also,for more leaf spring support. I have my Trans angle sloping 7 degrees, my rear pinion points up 4 degrees, my driveshaft is at a 3 degree slope down. I set the rear pinon at 4 up to take into consideration of the axle to turn upwards a tad with accelation. Is this setup gonna work, thanks for your input. 383 stroker, 450 horse, 700r4 trans Ford 8.8 rear
  2. Make the tail shaft and the pinion lay at the same angle. You are not going to get much spring wrap if any with ladder bars. You did use floaters on the rear right?
    Hnstray likes this.
  3. swaluda
    swaluda
    from pa.
    yeah,we got floaters
  4. gimpyshotrods
    gimpyshotrods
    If you run at 7º, you may experience vibration at freeway speeds.
    I would bring the transmission up to 3º, and set the rear there too.
    Hnstray likes this.
  5. Texas Webb
    Texas Webb
    3 down trans-3up rear.
    pitman likes this.
  6. vtx1800
    vtx1800
    If you have a smartphone, Tremec has an app that you can use to set the pinion angle with, it's a slick app.
  7. This will complicate it for sure. I've got a double CARDEN JOINT (2 u joints) for my front u joint because I run steep angles.
    I was told to match the pinion angle to the driveshaft angle. Does this sound right?
    Engine / Transmission is negative downhill 4 degrees. The driveshaft is 1/2 degree uphill currently and I've got a harmonic vibration.
    That would tell me the rear-end pinion ought to sit at ????
  8. Da Tinman
    Da Tinman
    With a CV shaft like yours the pinion angle should match the driveshaft angle. If not you will have a vibration.
    Here's what it looks like on my Jeep.
    Not a monster truck though.
  9. Da Tinman.....Yes that explains clearly what other folks told me.
    I'm going to attack it this week and try matching the driveshaft inclination angle.
