Technical Axle widths
Discussion in 'Traditional Hot Rods' started by Narum5, Mar 18, 2020.
  1. Narum5
    Narum5
    Got a 30 model A that I want to run the wheels out side of the body. I have a 97 Crown Vic rear end but it’s to long. About 69” face plate to face plate. Would like to be around 63-65” 5x4.5 bolt pattern. What Vehicles should I be looking for?
  2. Width for an A-bone should be 55-56” wheel mount surface to wheel mount surface. Google axle widths or 8” axles widths or variations on that theme.
    gimpyshotrods likes this.
  3. PackardV8
    PackardV8
    Studebakers with Dana 27 for light duty and Dana 44 for heavy duty are about the width you need, have 5-on-4.5" bolt pattern, post-'57 often have TwinTraction.
    jack vines
    dana barlow likes this.
  4. Marty Strode
    Marty Strode
    Maverick 8" is 56" overall width.
    winduptoy likes this.
  5. gimpyshotrods
    gimpyshotrods
    Ford 8.8, from a 1990-1992 Ford Ranger pickup is 56.5" wide, has a variety of ratios to choose from, often with limited slip, has the bolt pattern you are looking for, and are plentiful in salvage yards. They are cheap, and all of the parts for them are still in the auto parts stores.
    There are 7.5 rears in these, too, so make sure you learn how to spot the correct one.
    brokedownbiker likes this.
  6. Narum5
    Narum5
    To narrow. Out side body of the A is 55” I need 65” Mounting surface to mounting surface. IMG_3816.JPG
  7. alchemy
    alchemy
    He's channelling it to the GROUND!
    flatford39 likes this.
  8. thirtytwo
    thirtytwo
    The 73-80s f-100s some had 5x4.5 pattern and are close to width you are asking for I believe
    Narum5 likes this.
  9. gimpyshotrods
    gimpyshotrods
    Going to be tough to drive.
  10. powderfinger
    powderfinger
    I have a complete rear end out of an early 60s Chevy that works for mine. It came out of an old dirt track car and is the correct width.
  11. brokedownbiker
    brokedownbiker
    That's what I used under my Shoebox. Exact width as the original, 3.55 gears. Works like a champ
  12. fastcar1953
    fastcar1953
    96 and up ford explorer 8.8 even comes with disc brakes.
  13. 41rodderz
    41rodderz
    from Oregon
    It helps if we know where you are from . Can’t throw a dog a bone if have no idea what neighborhood he is running around in .:D
    town sedan likes this.
  14. Narum5
    Narum5
    Not sure why that’s relevant but I am from North Dakota
  15. Mimilan
    Mimilan
    60-1/2"
    Narum5 likes this.
  16. gimpyshotrods
    gimpyshotrods
    Because people know of locations of parts, yards, and may have parts that they can sell you, who are nearby your location, or p*** by it.
    This is, after all, a network of people who build cars, that spans the globe.
    town sedan, JeffB2 and Narum5 like this.
  17. gimpyshotrods
    gimpyshotrods
    At the with you are looking for, you are into truck/van/SUV stuff, which will not have the bolt pattern you are looking for.
  18. Narum5
    Narum5
    97-98 f150 is about the width I want and the bolt pattern. Might try and find one of those. Some have disc and some with drum.
  19. thirtytwo
    thirtytwo
    Pretty sure that is a 5x5.5 pattern might even be that same stupid metric pattern they used a couple years later
  20. fastcar1953
    fastcar1953
  21. fastcar1953
    fastcar1953
  22. lake_harley
    lake_harley
    ^^^^^Great reference. Thanks.
    Lynn
  23. Kevin Ardinger
    Kevin Ardinger
    I believe mine is 60, 62? if I’m not mistaken. 9” from a 79 F150. If I had it to do over I would use an 8.8
    Narum5 likes this.
  24. Narum5
    Narum5
    These are the three bolt patterns I can use to work with. 5X5, 5x4 1/2, 5x4 3/4[​IMG]
  25. mitch 36
    mitch 36
    I don’t think I would trust that wheel on anything, not much meat left, just my opinion though. Mitch
  26. Hnstray
    Hnstray
    from Quincy, IL
    @mitch 36 ^^^^^^^^exactly what I was thinking.....
    Ray
    WiredSpider and lucky ink like this.
  27. Kevin Ardinger
    Kevin Ardinger
    pretty sure a crown vic 8.8 will go right in there
  28. dana barlow
    dana barlow
    from Miami Fla.
    Many have talked about this or that rear,so likely one of those may work fine.
    Mostly it dosen't matter,except if you don't want to look for or make a pair of rims for rear you have !
    But; I didn't start out when building cars,ever thinking much about how wide or narrow a rear that I could find free or close to free was! I know that rim off set can put a tire at a wider or narrow track by how much off set or inset of the rim. Also learned how to move rim centers my self pretty early.
    Some now days are locked into a idea of matching front to back rims. In the 50 n 60s,frankly we just wanted the hub caps to match if we could and tires not rub,with low scrub on fronts.
    Dose seem to be a lot less DIY now days,just buy it. Too bad.
  29. 2OLD2FAST
    2OLD2FAST
    from illinois
    Function follows form , appearances are everything ,comfort is not considered ( especially when you're young and invincible) ....
  30. 2OLD2FAST
    2OLD2FAST
    from illinois
    Face it Dana , those of us without big bank accounts are dinosaurs ...
    town sedan, X-cpe and dana barlow like this.
