Features B&M Hydro stick installation instructions
Discussion in 'Traditional Hot Rods' started by backyardbeliever, Nov 9, 2006.
  1. willys36
    willys36
    Yes, that valve you are holding is the first gear locker that the Spar Bros. invented. Since Dusal Range Hydramatics didn't have torque converters, GM designed a very low first gear and no provison to hold it there so the ****** automatically shifts to second @ ~10-15mph. This was the factory's answer to a torque converter. Modified B&M Hydros came with that valve but racers rarely if ever used it. On a strip launch, the need to 1-2 shift came up so quickly that racers started out in second letting the 1-2 be their 'torque converter' as GM designed it. Thus the thing that put B&M on the map had little use in drag racing, lending itself more to off road mud driving!
    Incidentally, your valve is missing the plunger. I'll post a picture or two of how the thing goes in the ******.
  2. well I've put this out several times but since this post is hanging well I'll try again.
    looking for a Hemi to Hydro adapter. at this point I don't really care how reasonable it is
  3. Blownolds
    Blownolds
    from So Cal
    I have a hemi-to-hydro flywheel for $300 plus shipping, but no adapter-- sorry.
  4. backyardbeliever
    backyardbeliever
    i will surely be carefull when i dissasemble it. ive got a feeling that its most likely not much differnt inside than any other early cad single range of that era. but curiousoty is killin me sorry im a little slow on this one but the day after i got it i had to go to costa rica which is where i am now on the hotel comp. The other ***embled hydro,s i have are chevy truck thats built and ready to go racin and 2 - 55 cad units and lots of internals left over from my dads hydro days of building them for strip cars bands and dual range valve bodies make up most of it though. its funny what you said about gettin info from old hydro guys ive had the same experence in that they dont even wanna talk about em and cant understand why i have any interest in them. On the tank hydro another thing i noticed is that it has a short tailhousing with a mount on the bottom just like my 55 cad units but its a short tail like most hydros and not 2 ft long like later cad.I suspect its just stock early cad but i dont know. Like you said there is alot to know about hydros. You mentioned br*** clutch plates you mean like with no friction matt. bonded to them? Have you ever heard of hydro clutches like this? damn now you have my really really curious.
  5. backyardbeliever
    backyardbeliever
    what ive come to learn about this perticular mod. is the best mod is to do is not modify the stock tube but instead machine the governor WAY down so your 1-2 shift comes in at around 6000 or so depending on how much you cut off. cause like you said there is other things for the driver to be doing 10 ft out of the hole than trying to shift to second because first is ridicoulsly low. Also i have a valve ***y thats in a ****** i have its just not a cool lookin b & M one so i didnt post a pic of it . my thought on the first gear reason was more that these ******'s came in very heavy cars that were relitively under powered. If you look at the different ratios of the differnt cars you will notice that there all different and that comerical service vehicles and cadillac had the lowest first gear ratios. Its the job of the torus ***y. to provide the function of the engine to continue running while the car is not moving while in gear . which is why it only has the duty idleing in gear and the 1-2 shift and is not in use after that. The 2-3 and 3-4 shifts are direct and do not use the torus. which also is why these ******s last and dont burn up there is nothing making HEAT most of the time. the spend very little of their life using the torus ***y. I would like to see b&m's valve if you have a pic of it. Thanks
  6. yorgatron
    yorgatron
    so if you were to cut down the vanes on the torus to raise the stall speed it wouldn't affect the normal driving? :confused:
  7. I used a half dollar piece marked them about 3/4 inch from the center to get 3000-3500 stall,
  8. willys36
    willys36
    Here is B&M's valve installed. When I first modified my ****** I didn't have a B&M valve so I made one out of aluminum bar stock and a piece of steel rod. Works great. Regardless, really is no reason for it in a drag car. Starting out in 2nd, allowing an auto 1-2 shift then manually shifting the rest works pefectly.
    Also, here are a couple photos of the military version. Quite a bit different from the auto one. Has a cast iron bottom pan, different dip stick boss cast into the body. These things were used in military tanks during WWII so a little service behind a blown 400' engine is no sweat!
    [​IMG][​IMG]
  9. Blownolds
    Blownolds
    from So Cal
    Wow, never saw a pic of a military unit-- thanks!
    As for what I mentioned about br*** clutches, I mean solid br*** or br***-alloy clutch discs. I understand this is what were in tank trannies, as well as what the Dynaflow clutches were supposed to be.
    I also understand that while they are good for high-heat, the br*** shavings that wear off tend to clog up the valve body. Just what I've heard. I plan on having a small production run of Red Alto kevlar clutches done when I'm ready for them. But that sort of small production run type of thing is NOT CHEAP and I'm a long ways from needing them yet. Too many other areas of my project to concentrate on.
  10. cadillac dave
    cadillac dave
    i am running a hydro in my 31 roadster. just scored a pile of n.o.s. hydro parts from a pontiac dealer. nice catalog. cadillac dave
  11. Blownolds
    Blownolds
    from So Cal
    I wouldn't say that. Just raising the stall speed affects normal driving! But besides that, I understand that the higher the stall, the more slippage at high RPM. Or maybe that should be rephrased to more horspeower being lost by the two torus halves not transferring it all. Remember that the drive torus moves the driven torus by basically fanning past it and the fluid getting pushed by the vanes. Cut the vanes down and they can't move the fluid as well. This is why the stall speed goes up before the car starts to move. You gotta rev the engine (and subsequently the flywheel, torus bowl, and the drive torus) higher to get the driven torus to start to move. At least that's my take on it, and my understanding. It just makes sense to me that the efficiency of the torus ***embly goes down when you start shaving the vanes back for higher stall.
    That being said, it should be noted that there are differences in the toruses from model to model and year to year. I have seen several different ones. I plan on starting out with the small 10-1/2" diametewr Chevy truck torus in un-modified form, and then only making modifications to the vanes if necessary.
  12. willys36
    willys36
    You are correct, cutting the vanes raises stall speed but also decreases mechanical efficiency across the RPM range. Less fuel efficiency and more heat generation is the result. Hydros are super sensitive to vane cutting and as B&M stressed in their 60s sales literature, get the tori configured EXACTLY for the type of driving you plan to do. Cutting too much or too little for your application is disasterous. My recommendation for the street is get the 10 1/2" 'Chevy' torus and use it in the big Olds/Caddy torus cover instead of the larger big-car tori. Since torque generation is a function of torus diameter to the 5th power, the smaller Chevy unit will increase the stall speed w/o loss of efficiency at speed.
  13. Blownolds
    Blownolds
    from So Cal
    For folks using a Chevy engine, I think I'd recommend using the smaller-diameter 18-bolt Chevy torus bowl as well. I don't believe you can attach a large 30-bolt Olds/Cad/Pontiac torus bowl to a Chevy hydro flywheel. Unless you know different.
  14. willys36
    willys36
    That's correct. Sorry, I am always thinking hemi!
  15. unclescooby
    unclescooby
    from indy
    I just got this unit behind my Lincoln 368 and I don't know a thing about them. I'm hoping this post goes forever...
  16. Well looks like forever stopped over five years ago but I'm turning back the time. Gathering parts for a front engine Corvair racecar and I want a Hydro.
  17. Am glad to see this thread revisited!!
  18. brechlrl
    brechlrl
    from Wisconsin
    Is there a way to tell anything about a B&M from the numbers on the tag?
  19. gasserjohn
    gasserjohn
    backintheday i bought a nos b/m
    called b/m gave serial #off tag ...recently phoned b/m was told only one guy there had any knowledge about old stuff ...kept calling back finally got him he was able to copy & sent me all old paper work he still had
    will look thru old files to find his name
    told that it was ordered for a blown bbc motor
    ran it in my 327 modelA got it upto 5grand 'stall' only once....
    ran for many years w/o cooler ...no problems/locked pressure wide open
    have never had a trans that shifted that hard..........have two =1b/m hydrostick .... 1 built by Kilgore with close ratio pontiac gears was better then the b/m
  20. tommyd
    tommyd
    from South Indy
    I'm glad this thread got revived. This trans is why the Chevy sedan delivery would out run our C.J. Fairlane sometimes. I'm guessing?
  21. magooz
    magooz
    Hi Guys,
    We're building a '50 OLDS Coupe with a '57 Olds J-2 punched 1/8" to 394 cu in. Using a B&M Slantpan Hydrostick & original B&M GATE shifter (VERY RARE) from the 60's we found in lower Ca. We're in the process of installing now.
  22. soca92126
    soca92126
    Hi, First time on here but I do have some b&m hydro stuff. Thanx Dominic
  23. Speedy Canuck
    Speedy Canuck
  24. powrshftr
    powrshftr
    If you've got a shifter,I need it!
    The guy I bought my HydroStick from sold it before I could get it from him
  25. Speedy Canuck
    Speedy Canuck
    I know of a guy with a Sparkomatic aftermarket shifter for sale.
    I also believe Blindowl still has most of a B&M shifter that would have been aftermarket for a stock hydramatic trans. Should work just fine though. Believe he still has it for sale.
  26. Speedy Canuck
    Speedy Canuck
    I don't think I've actually shared any of my Hydro stuff on here. In the Hydro Tech group, but not on the main board. Here it goes...
    B&M Hydro Stick shifter
    Ansen Posi-Matic Hydro Shifter
    Kent Moore J-5071 Rear Servo Gauge
    Kent Moore J-2681 External Band Adjustment Tool
    Snap-On ATC-50 External Band Adjustment Tool
    New Britain AH-11 Front Servo Gauge
    I don't have a picture of my Hurst Hydro/Gate, but I have one at home.
    Lots more pictures, parts, and tech that I've compiled in the Hydro Tech group. Find it here: http://www.jalopyjournal.com/forum/group.php?groupid=791
  27. powrshftr
    powrshftr
    Now you're just toying with my emotions,Man....! Lol!
    Scott
  28. Speedy Canuck
    Speedy Canuck
    If I can find another Front Servo Gauge for an affordable price, I'll have a second set of the main tools to loan out.
    Unfortunately the shifters aren't for sale, but you did see my leads for a shifter on that above post, right?
  29. powrshftr
    powrshftr
    Yes!
    Thanks a bunch Man,you made my day!
    I'm flying home tomorrow,so I will drop mine off at the shop and see what the old Hydro Ace thinks of it...
    Right now,Im gonna send some pm's about a shifter....:)
    Scott
