  1. I'm getting ready to install my 1955 270 hemi in my 1931 ford coupe.. my question is how much is an except able amount of motor tilt back.. I have it at about 5 degrees tilted back any more level than that the transmission begins to not be level.. I hope this makes sense.. I'm really looking for help on this guys
  2. Anyone
  3. ol-nobull
    ol-nobull
    Hi & welcome. As this is the place where you introduce yourself and tell a bit about what you drive and here you live just a few of the HAMB members frequent this board.
    For technical info & help you will do better posting your question on the Hokey *** message Board.
    Not being either a Hemi or a Model A guy I cannot help with your question.
    Jimmie
  4. Ok thank you the mobile app for this site really is not user friendly.. and thank you again
  5. Mopar'd
    Mopar'd
    I would level the carb mounting flange on the in the intake. This requires that the is set close to ride height.
    lothiandon1940 likes this.
  6. Andy
    Andy
    I would try to set the rear suspension position versus the frame. You can then set the driveshaft angles. The engine tilt is controlled by getting the driveshaft angles right.
