Technical Baby Moon Hubcaps
Discussion in 'The Hokey Ass Message Board' started by bobg1951chevy, Oct 1, 2016.
  1. I have baby moon hubcaps on 15 X 6 chrome reverse style wheels ..... from Coker.
    But, instead of chrome plating, my "reverse wheels" were powder coated red.
    The hub cap is very shallow, almost flat against the center of the rim.
    Don't want to damage the paint, or the cap, trying to remove these caps.
    Has anyone used an idea that works, to pry off the cap, without damaging the cap or the painted wheel surface ?
  2. cretin
    cretin
    I'm confused. Are your wheels chrome, powder coated, or painted, because you say they are all 3.
    Greenblade and X38 like this.
  3. Here is what I said in my first post.
    "But, instead of chrome plating, my "reverse wheels" were powder coated red."
    The wheels are deep dish, big offset.
    Guess I could have written my post better and clearer.
    Maybe the below will make more sense.
    Don't want to damage the powder coating , or the cap, trying to remove these caps.
    Has anyone used an idea that works, to pry off the cap, without damaging the cap or the powder coated wheel surface ?
  4. cretin
    cretin
    I'm well aware of what you wrote in your first post, and as you can see in bold, you referenced all 3.
    Anyway, I can only ***ume that maybe you have a chrome rim with powder coated centers, and you want to remove the cap without damaging the coated center.
    I have used a bent and taped up screwdriver with a rag, and I have also used the plastic interior pry tools.
    Good luck.
  5. Jet96
    Jet96
    from WY
    I've used the 90 degree nylon interior trim removal tool from my cheap harbor freight kit,
  6. Boyd Wylie
    Boyd Wylie
    Buy a small Stanley Nail Puller.It has a 90* bend at one end. Wrap a rag around it and pry. I use one on Rally Rims and other Hubcap style wheels
    bobg1951chevy likes this.
  7. lothiandon1940
    lothiandon1940
    Bob Drake sells this tool he calls a Wheel Wizard. It actually works pretty well. The above suggestions work well also. tl-110_med.jpg
  8. upspirate
    upspirate
    bobg1951chevy and lothiandon1940 like this.
  9. upspirate
    upspirate
    It even has flames!
  10. BLUDICE
    BLUDICE
    I drilled a 1/8" hole on the flat edge of the cap, then to remove the cap simply stick a 90* pick in the hole and pull the cap off.
  11. 19Fordy
    19Fordy
    Use a plastic bondo spreader with oil on the leading edge.
    You may have to "tap" it with a hammer.
  12. unkledaddy
    unkledaddy
    Did you try just using your fingers?
  13. Lebowski
    Lebowski
    Who still makes strong and sturdy baby moons? The last set I bought was made in China and when I put them on they dented very easily because of the thin metal....
  14. colordeluxe
    colordeluxe
    I don't think anyone makes real ones anymore, after long search I lucked out and found some N.O.S. ones at a swap meet in Arizona. Try a "wanted ad", you may pick one up here and there.
  15. 2935ford
    2935ford
    I also use a small screw driver taped and a rag.
    Not to go too far astray but talking about Baby Moons..........anyone these days make the "real" ones with the nicely rolled edge that snaps nicely into place over the nubs?
    The offshore units are trash.
  16. Tried fingers only, can't get fingers in there because baby moon is somewhat recessed, or sunken into the rim itself.
  17. jimmy six
    jimmy six
    I like the hole idea but make sure u have a folded towel or some other pading to catch the cap. More dings happen after its released.
    Jet96 and lothiandon1940 like this.
  18. 55 Ford Gasser
    55 Ford Gasser
    Sounds like you actually have a smoothie wheel. The baby moon snaps inside rather than over the nubs.
    Jet96 and bobg1951chevy like this.
  19. Exactly !
    Thank you, I could not recall the key word "smoothie".
    My old mind doesn't compute the words, each time I need information.:(
    lothiandon1940 likes this.
  20. pprather
    pprather
    I use this method also with an old fashioned dent puller, somewhat like the HF item shown.
    Pull with one hand, keep the other hand on the cap so it does no damage when it pops loose.
    Sent from my Nexus 7 using The H.A.M.B. mobile app
  21. 41 C28
    41 C28
    I use a reproduction old style VW Beetle hub cap puller. You'll have to drill two small holes to match the puller.
  22. AVater
    AVater
    That's what I do
    lothiandon1940 and bobg1951chevy like this.
  23. Hotrodmyk
    Hotrodmyk
    Here's what I have. I have used the plastic HF tool as mentioned above. I currently use the Drake tool. Both OK.
  24. We have the same wheel and cap. No trim ring on mine.
    Do you find that the Drake tool tends to bend or crimp or damage the cap, in any way ?
  25. Hotrodmyk
    Hotrodmyk
    ^^^^^^Hasn't yet
  26. lothiandon1940
    lothiandon1940
    ...............If used correctly it's pretty fool proof.
    lothianwilly71 and bobg1951chevy like this.
  27. LBCD
    LBCD
    I too use the interior trim tools from harbor freight. $10 [​IMG]
    Sent from my SCH-I535 using The H.A.M.B. mobile app
  28. Lone Star Mopar
    Lone Star Mopar
    HF sells a hubcap tool, it wedges under the cap and has a rubber snubber that pushes on the tire and pops the cap off. They're like 10$ and work well
    Sent from my SAMSUNG-SM-N900A using The H.A.M.B. mobile app
  29. pat59
    pat59
    I use a little oak wood wedge and tap it with a little steel hammer.
  30. lothiandon1940
    lothiandon1940
    .....................That's "ole school" right there.:D
