Technical backfire under load
Discussion in 'Traditional Customs' started by genebrownlow, Mar 21, 2021.
  1. genebrownlow
    genebrownlow
    Ok I have begun to have a backfire issue when I extend acceleration in first and second. (3 speed on the tree). It only happens after the engine has heated up to 170. Before that it runs great. After choke open it runs really strong. This is a 1962 327 with a Holley 600 CFM, Pertronix ignition. I have checked timing (4 degrees above). Wiring on distributor is correct. It has an electric choke and seems to be adjusted correct and is open all the way after engine warms up. I have checked the float and it is correct.
    I saw that the radiator hose was touching the fuel line so I realigned thinking it might be creating a vapor lock but no help there. I understand a lean condition can cause issues like this but The car ran great a couple of weeks ago. The only thing I have done under the hood is change the radiator. Before that I was having an issue with the engine dying when I turn left but I found there was no ground from the engine and I installed one and that corrected the dying problem.
    Any ideas?
  2. 2OLD2FAST
    2OLD2FAST
    from illinois
    Fouled plugs or bad plug wires , cap & rotor in other words , a weak spark ..
    Bob Lowry and genebrownlow like this.
  3. genebrownlow
    genebrownlow
    I checked the plugs and they look fine. No fouling there. I guess it could be wires but the car runs fine unless I push it beyond a normal take off from dead stop or extend second gear. Maybe opening the back two on the Holley.
    Also remember while the car is warming up it runs really strong. Even when I open up the back two on the Holley it pulls really strong and engine sounds great.
  4. Mr48chev
    Are both advance mechanisms in the distributor working correctly?
    You didn't by chance kink or twist the fuel line when you realigned it? My experience with a fuel line restriction on a 327 was that the carbs ran out of gas on hard acceleration and the bowls filled up when I let off and shifted and then ran out of gas again when I topped out ins second. That was 4 WCFBs on a Corvette intake with an engine with an Engle cam 12.5 pistons and 2.02 heads. No popping back just running out of gas until I let off.
    I'd be checking for the little things though. Loose wire or connection inside the distributor. Check the screws that hold things down to make sure that they are tight. Check any ground wire inside the distributor. Make sure that the top of the coil is clean and doesn't have anything that might cause a spark jump issue. Check inside the cap for carbon tracking. Check the contact for the rotor inside the cap. We always hunt for the big things but forget to look at the little things.
    genebrownlow and Truck64 like this.
  5. Backfire,,,,,,through the carb ?
    Tommy
    ClayMart and TA DAD like this.
  6. genebrownlow
    genebrownlow
    yes backfire through carb. Only after the engine has warmed up. Again, before that the engine runs great. For maybe 10 or 15 miles. Great acceleration and engine pulls hard. Then when the temp gets up about 170 if I push the engine I get the backfire. One other thing I put a fuel press gauge on and the pump is maintaining 6.5 psi.
  7. Harv
    Harv
    from Sydney
    Car runs fine when cold (choke shut)... the richer mixture may be hiding a lean-out in the power or accelerator circuits. Choke opens, mixture goes lean, and the lean-out becomes evident.
    Does the miss occur when you initially mash the throttle (accelerator pump), or a little later, when the engine spools up (secondaries)?
    To check, frig the choke shut (or partially shut) and see if it still does it.
    Cheers,
    Harv
    WB69, 67drake and genebrownlow like this.
  8. 270ci
    270ci
    Solid or hydraulic lifters?
    ClayMart likes this.
  9. genebrownlow
    genebrownlow
  10. ROADSTER1927
    ROADSTER1927
    :)I agree with Harv wire the choke a little shut and try it!
  11. 270ci
    270ci
    Hmmm, then it won't make any sense to suggest you might have an intake valve or two with lash set too tight.
    Resetting valves cured the same symptoms you're having on a solid lifter motor I had awhile back.
  12. TCATTC
    TCATTC
    Lobe wear on your camshaft?
    Center of the Galaxie likes this.
  13. Exactly what I'm thinking. I hope not, but ...
  14. jaracer
    jaracer
    Find someone who has an ignition scope and knows how to use it. You can eliminate any ignition problem in less than 15 minutes with a scope.
    genebrownlow likes this.
  15. Black Panther
    Black Panther
    from SoCal
    Spark plug wires performance fail under heat and load. Car could idle beautifully, rev out in neutral like it's fine, and **** out under load...especially when the engine is warm/hot.
    genebrownlow and foolthrottle like this.
  16. spanners
    spanners
    Warm engine, intake manifold or carb gasket leaking vacuum .
    foolthrottle likes this.
  17. chopper99
    chopper99
    Check very closely for an intake manifold leak.
  18. chevyfordman
    chevyfordman
    Do a compression check
    COCONUTS likes this.
  19. 2OLD2FAST
    2OLD2FAST
    from illinois
    Jack up the radiator cap & put a new car under it ..
  20. genebrownlow
    genebrownlow
  21. Baumi
    Baumi
    Beautiful 57!
    My wife´s 53 Suburban had a backfire through the carb under acceleration, it also has a 327. It had a flat lobe on #1 exhaust valve.I´could still kick myself for using a cheapo enginetech cam.Finally the worn lobe wouldn´t open the valve enough to vent the gases through the exhaust, so it popped back into the intake and through the carb. I cross my fingers you ´ve got a different issue...
  22. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Does it do it when its warm but sitting still and reved up..............or only under load and reved up?
    If you can replicate it sitting still, I would wait till its good and dark and rev it and see if you can see any spark issues when its dark. Could just be a bad ground connection. When it does backfire, is it continuous or kinda random?
  23. Oilguy
    Oilguy
    I too vote for a flat cam lobe.
  24. jimmy six
    jimmy six
    A lobe can be easily detected if your needed to adjust one often or by looking a valve movement with the covers off. A push ****on cord really helps and no ignition needs to be on.
  25. Roothawg
    Roothawg
    So, a little more info please.
    Has it always done this?
    Is this car new to you or do you know the history?
    What has changed before this started? Any recent maintenance?
  26. genebrownlow
    genebrownlow
    OK found it! I always seem to make it more complicated than it really is.. ACTUALLY was thinking it had to be something related to one of the 5 or 6 things I had done in the last few weeks because it just started recently.
    However, the troubleshooting trophy will be shared by..... 2OLD2FAST (even though he wanted me to just keep the radiator cap and install a new car!) and Black Panther..... Thanks guys for reminding me to look for the simple things first.
    The wires had just been replaced right before I bought the car but must have been on the cheap side. Change the plug wires and it runs great again.
    I did like all the suggestions and I am sure if I had given more or better information you guys would have zoned in on the problem like 2OLD2FAST and Black Panther. Thanks for all you input. This is a great website because of you guys!
  27. 50 Merc Man
    50 Merc Man
    Timing
  28. genebrownlow
    genebrownlow
    no sir.... plug wires.....
  29. Black Panther
    Black Panther
    from SoCal
    You got it buddy! It is always best to start with the easy stuff first. People talking about cam lobes on this thread confuse me..if it was a cam lobe it would be running ****py always...the temperature wouldn't matter. If the lobe is flat or going south it will always be. A problem that occurs at temperature instead of a cold engine, will most likely be electrical...second option would be to look at the fuel system. That's been my experience..
  30. Interesting comment. I get it, start with the easy stuff first. However a cam lobe that is just starting to disappear is going to behave differently than one that is flat or nearly flat. An exhaust lobe that is completely worn flat or nearly flat will behave like a broken rocker arm and backfire with a regular rhythm. An exhaust lobe that is worn just enough will only misbehave under acceleration and can be temperature sensitive as well. I diagnosed and replaced dozens of camshafts in late 70s and early 80s Chevy smallblocks and saw a few that behaved that way.
