Technical Backfiring 327
Discussion in 'Traditional Hot Rods' started by verr1908, Jun 28, 2025.
  1. 19Eddy30
    19Eddy30
    from VA
    @verr1908
    Patronix is 50 / 50 . Many threads about here on HAMB .
    I have had Very good luck with
    Mallory since introduced late 80s
    Early 90s , as long as wired correct
    Use Ballast &
    "" Do Not Weld on Vehicle "
    Unless you
    Disconnecting battery or unplugged wire harness to distributor.
    Usually can pick one used up for
    $50 -70,
    Its a gamble on eye / module tho.
    Tow Truck Tom likes this.
  2. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Bigger F H
    anthony myrick and Sharpone like this.
  3. Sharpone
    Sharpone
    Always works have @anthony myrick stop by he loves to hit cars with hammers lol
    Dan
    Tow Truck Tom and anthony myrick like this.
  4. I’ve made some neat recesses to clear em. Used hammers to make em
    Setting up engine mounts always includes fitting the dizzy.
    Tow Truck Tom, patsurf and Sharpone like this.
  5. 1biggun
    1biggun
    If you can install a pertonix in there you can install points especially unipoints just as easy or easier .
    If you can't get the cap off then redesign the car so you can .
    Sharpone and anthony myrick like this.
  6. winduptoy
    winduptoy
    Did you look at the intake port to head port alignment and size, then the intake gasket 'cover' and alignment? there are a bizillion intake gaskets and they necessarily don't all align and cover what they should. My 327 with angle plug heads and aftermarket Offy 3x2 intake was leaking on the valley side of the set up because of a mis-match gasket....
    just a thought and kind of wonder what manifold vacuum looks like at idle?
    theHIGHLANDER, Sharpone and alanp561 like this.
  7. verr1908
    verr1908
    from england
    Well guys update pulled the distributor to fit the pertronix kit to find the base plate bearing had come apart ,so distributor is s**** picked it up new boxed at a swap meet 4 years back , I have the original distributor Delco remy with vacuum advance 1110847 serial number 6d30 but had no cap or rotor arm ,may have to try use it ?
    Sharpone likes this.
  8. verr1908
    verr1908
    from england
    Today’s update all back together today , with new duel plane manifold with new gaskets, distributor base plate repaired with petronix kit and flamethrower coil ,new carburetor with electric choke ,new leads , plugs , time set to 13 BTDC . Starts perfect ticks over and revs out great when sat in my workshop ,BUT again has such a flat spot with out feathering the throttle will almost cut out . I have blocked of the vacuum advance still the same .swopped vacuum port across to the other port still the same . Just about to set fire to it
    GlassThamesDoug and Sharpone like this.
  9. Oneball
    Oneball
    Whereabouts are in England are you?
    Sharpone and Algoma56 like this.
  10. 19Eddy30
    19Eddy30
    from VA
    @verr1908
    Yes , can be frustrating at times,
    If Avatar too nice to throw a match on.
    Flat spot / bog ... Get a can of Brake clean / carb cleaner when you wack throttle & @ died Flat spot ,Spray into carb & see if it camouflage Dead spot.
    & takes it , Rev's up No bog.
    If so you know Accelerator pump needs adjusting Not enough fuel shot or squirter size to small ,
    If Not take some away , accelerator pump squirter size,
    Could Be still need more Initial timing.
    Could be where you have carb set , ****erfly's p*** transfer slot
    ( Flat spot /Bog) at the bottom of the bore of the base plate.
    On Front Bore's .
    Just saying Air , Fuel , Spark & Timing .
    Jibs and Sharpone like this.
  11. verr1908
    verr1908
    from england
    Leeds yorkshire
  12. Oneball
    Oneball
    I was up there last week. Darn
    I still think your timing is out. With it running move the distributor to get the fastest idle, retard it a couple of degrees and see what it drives like. Ignore what the timing marks say.
  13. patsurf
    patsurf
    as a second to your advice--advance it til it kicks back a bit on starting and just back off from there enough-seems the quickest dirtiest way...
    Sharpone, Oneball and winduptoy like this.
  14. winduptoy
    winduptoy
    I'm thinking the same....
    Sharpone and Oneball like this.
  15. verr1908
    verr1908
    from england
    Timing set at 13 BTDC also check damper makes again timing case which is TDC , but I wll give it ago , thanks
  16. verr1908
    verr1908
    from england
    Update turned dizzy to fast idle then backed it off few degrees, so took it out for a drive no flat spots or coughing and check timing on my return set to 38 degrees BTDC ,but would not restart knocked timing back to 22 degrees need to take it out again tomorrow.
    GlassThamesDoug likes this.
  17. sunbeam
    sunbeam
    Totally agree at 180 out there is no compression when you have spark
  18. verr1908
    verr1908
    from england
    22 BTDC with vacuum advance pipe clamped if I unclamp pushed the timing to 40 BTDC , using the vac port on the base of the edelbrock 4 barrel have tried both side still the same ,but drives better still not great
  19. theHIGHLANDER
    theHIGHLANDER
    The timing should back off at the 1st whack of the throttle. Vacuum "advance" is a load compensation system. Vac drops on accel, timing retards so it doesn't detonate or backfire, as vacuum increases during accel timing advances commensurate with engine speed/demand. Elegantly simple and effective. If you're confident in the ign timing your accel flat spot could be pump volume. I can't see the carb but sometimes there's 2 holes for the arm to mount, one with longer pump shot duration than the other. If you like what you see in volume then duration may bring it in. If it seems like pump shot has prostate issues you might opt for bigger shooters if they're available for it.
    So all of that aside, I didn't see mention of the carb secondary action. Has it been set up to foot demand (mechanical all open) or vacuum secondary function based on engine demand? If all 4 open manually that has to be accommodated with extra pump volume. If it has the upper air valve style there's a spring adjustment that will reduce secondary air until the engine speed demands more. Raw thoughts...
