Hot Rods Backing plate brake drum gap
Discussion in 'The Hokey Ass Message Board' started by texkbc, Apr 23, 2020.
  1. texkbc
    texkbc
    I am trying to determine why I have gap at bottom of packing plate and drum. Any suggestions? I don’t this is supposed to be this way . 868A697C-1C3C-44B1-A698-56D7916EE606.jpeg 1AA07576-0E6C-4D01-9EBE-599D9E5EDEF4.jpeg
    Stogy likes this.
  2. squirrel
    Those early Fords weren't designed to have Bendix brakes, so things work, but don't fit exactly right.
    is my guess
    Stogy and dana barlow like this.
  3. gimpyshotrods
    gimpyshotrods
    Does it stop ok?
    Stogy likes this.
  4. texkbc
    texkbc
    Yes it stops very good.
  5. gimpyshotrods
    gimpyshotrods
    Then don't over think things.
    You're good. It's done.
  6. rusty valley
    rusty valley
    the 34 fords had a triangle shaped plate that has 3 holes for the steering box bolts that was originally on the outside of the frame rail to keep the nuts from gouging into the slotted adjustment holes. yours, like most, is missing. its an easy part to make and really makes it so you can tighten down the box real snug. not made new, you make it IMG_1302.JPG
    Stogy and texkbc like this.
  7. dana barlow
    dana barlow
    from Miami Fla.
    The job of a baking plate{a**** other things} is to hold brake shoes in center of drum rub space. If you find the shoe is riding out on edge close to baking plate? Look for ways to move drum in more,or backing plate out more//if shoe rides were it should in drum,do nothing=it's fine and working as it should be. Stuff that was design to be together,or stuff that dose work to together,can be two def things as far as looks 100% right or not but still works right.
    Stogy, rusty valley and texkbc like this.
