Technical Backing plate straightening
Discussion in 'The Hokey Ass Message Board' started by Andy, Feb 20, 2024.
  1. Andy
    Andy
    I have a method of checking backing plates for warpage. The stuff is old and can get bent. I attach a strap to the hub and measure thru a hold in the end. I measure from the strap too the pads that the shoes ride on. If the measurements are off, the shoes will sit crooked in the drum. They don't work well like that. I note the dimensions and work to get them all close.
    I beat the plates in if needed with a sledge or pull them out with a bar with pads.
    All extremely crude. Friend welds them up and machines them down. I think my way is fine and cheap.
    I also have a way to check a rear end for warpage and how to straighten.
    3076543C-CAAB-4D04-86F4-81DC5F1A935F.jpeg A696E0E7-1CD7-4B45-A215-F058DE0EE432.jpeg 67C75207-2572-4F3A-B321-E8DD7C198AFD.jpeg A6AA3FBA-6C19-4CAE-973F-6309375850D2.jpeg 0E6C5A3B-70E5-4199-B348-B318C182876D.jpeg
    vtx1800, warbird1, alanp561 and 10 others like this.
  2. Budget36
    Budget36
    Please continue, Andy!
  3. Max Gearhead
    Max Gearhead
    from Wisconsin
  4. Cgrgrspt10
    Cgrgrspt10
    I suspect my backing plates on my GM 10 bolt are deformed by someone attempting to pry the drums off when they were stuck. I appreciate the measurement method. I would like to know how you levered the plates or unpuckered them. They have to come out, not in... How long was your bar? And what did you use as a fulcrum? Knock the car off the jack stands at some point. Thanks for the practical tech tip.
    Edit; holey **** is that what the rusty tube is? I gather the cutting torch hole is not related (?)
  5. Andy
    Andy
    That rusty tube is in fact the pry bar for bending them outward. The very end part grabs the plate lip and the middle part pushes near the center of the plate. It is 4 ft long. The super nice hole is not part of the process. The hammer is for bending in.
  6. warbird1
    warbird1
    I've had to do this with a couple pairs of reproduction backing plates from a reputable firm. Think they must warp badly when being stamped out.
    Andy likes this.
