Bad case of chatter
Discussion in 'The Hokey Ass Message Board' started by 59bug, Mar 17, 2010.
  1. 59bug
    59bug
    from missouri
    My 50 chevrolet had a bad case of chatter ( when you let out the clutch and the car jerkes, horribly). SO I figured it was the flywheel. So I took of the flywheel and replaced the clutch, throwout bearing, pressure plate, Everything. I put it all back together and it was fixed for about a day. Then she started jerking again. I have no idea and need your guys help. Do you think it was because I didnt have the flywheel turned. Thanks
  2. CAL
    CAL
    from Neosho Mo.
    In one word......Yes. Local machine shop here will resurface a flywheel for $25.00.
  3. wvenfield
    wvenfield
    Absolutely. You wasted your time without resurfacing the flywheel.
  4. 59bug
    59bug
    from missouri
    The flywheel I figured was ok because it wasn't new. I got it from my buddy who had it in his car and it was fine. Do you still think it is the flywheel.
  5. wvenfield
    wvenfield
    No, sorry, I was just lying.
    I don't think we would have said that you should have resurfaced the flywheel unless we thought you should have resurfaced the flywheel.
  6. holeshot
    holeshot
    from Waxahachie
    59 BUG...WOW WVENFIELD, testy. unfortunately it probably is the flywheel. listen even if they turn it, and they don't get it REAL smooth. then brother the problem isn't fixed. how do you know it's smooth enough, it will be almost slick...POP.
  7. tims37chevy
    tims37chevy
    from Minnesota
    Is it a closed drive shaft? If so could be the bushings in the torq tube or motor mounts
  8. wvenfield
    wvenfield
    LOL, sorry but I've never seen clutch chatter get fixed without addressing the flywheel.
    I imagine others have but if you replace everything except the flywheel and it still chatters, that leaves.............?
  9. Truckedup
    Truckedup
    I did many clutches without touching the flywheels and they had very little to no chatter.This guy's car is jumping up and down,right? Check out the pilot bearing and the ****** input bearing.And the driveshaft bush mentioned above.And the motor mounts and all the stuff mentioned in repair manuals for chattering clutch.
  10. VAPHEAD
    VAPHEAD
    I would say motor mounts are shot.
    If they are not holding the engine in place,you can get back and forth movement.
    And it shows up as chatter.
  11. wbrw32
    wbrw32
    Many things can cause chatter,In one case,I had the main shaft of ****** had enough rust build-up on it ,the clutch disc would not slide easily on the splines..so dont always ***ume its the flywheel !!! Henry Ford put those stay rods on flatheads to eliminate chatter,altho most were never put back as they were hell to stab
  12. medicinal_marinara
    medicinal_marinara
    from Oregon
    Motor mounts, crooked bellhousing, bad pilot bearing, off center transmission, oily clutch disc, or glazed/crazed flywheel all contribute to the problem.
  13. Beau
    Beau
    Drive shaft binding?
  14. wvenfield
    wvenfield
    Hundreds of thousands of clutches have been replaced without touching the flywheel.
    My point is that if you are replacing your clutch because of chatter, then while you have it apart, resuface the flywheel.
  15. 59bug
    59bug
    from missouri
    The mounts are good and yes it is an enclosed drive shaft. I'm gonna try the flywheel and hope it works. If you have more info about the bushings in the torque tube then that could be it too I guess. Man it just feels like the clutch is grabbing and then letting go and then grabbing again, make the car jump like crazy.
  16. junkyardjeff
    junkyardjeff
    Rear main seal leaking? Any oil that gets on the clutch will cause chattering.
  17. tony31a
    tony31a
    The fact that you said it was fixed for a day makes me think the disc is getting contaminated with oil. Was the old disc oil soaked?
  18. 59bug
    59bug
    from missouri
    I'm taking it apart today, but As far as I know no oil leak.
  19. BJR
    BJR
    Replace the pilot bearing/bushing when you have it apart.
  20. 333 Half Evil
    333 Half Evil
    DOUBLE CHECK THE SPRINGS IN THE CLUTCH DISC HUB. When you get it apart, take the cluth disc and shake it. If you can hear the springs rattle, then the disc is bad. You can even just grab the springs in the center hub and see if you can move them back and forth. If they are loose, this can cause the grabbing/shake you explained. I've seen many over the years that were bad right out of the box. A lot of reconditioned ones have this problem. When I sold clutches, I'd open them right on the counter in front of the customer to check them before even letting them out the door. You'd be suprised, as our clutch rep was, at how many of them are loose right off the shelf.
    So double check yours while it is apart...would hate to hear that you had the flywheel resurfaced, put it back together...and still chatters!!
  21. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Bad case of chatter
    I delt with that once...I told her to get out and walk
  22. wbrw32
    wbrw32
    You didnt have something "hard" to stick in it to keep it quiet ?
    Kinda hard to yap when their mouth is full
  23. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I was driving at the time.....hell i at least slowed down to 25 before she rolled out:D:eek:
    with her chompers running at such a high rate of speed i didnt feel like taking that kind of chance;)
