Bad Converter?
Discussion in 'The Hokey Ass Message Board' started by pigwilliams, Jun 27, 2009.
  1. pigwilliams
    pigwilliams
    I'm running a 700r trans and the engine is a 454, I've done alot of reading about the 700r trans and how to adjust or set the T.V. cable. My problem is when I come to a stop the trans does not want to downshift into low. It want's to hang up in second, it stumbles and if i don't go really slow to let it downshift it will stall the engine, i almost have to manually put the car in neutral so it won't stall. Any help is appreciated. Leave the "do a search" for someone else's post. The LARS was awesome last weekend!
  2. squirrel
    how is the lockup wired? and what's the engine idle speed?
  3. pigwilliams
    pigwilliams
    grounded and 12volts off ignition power off fuse block, 700 idle in drive.
  4. squirrel
    Did you rewire the lockup circuit in the transmission so it only engages in 4th?
  5. Shifty Shifterton
    Shifty Shifterton
    ^ what he said. If it's stock you've wired it to full time lock and there's a good chance it won't have much longevity. TCI makes a nice little kit to convert em over to non-ecm lockup, drop the pan and it's a handful of wires and a screw-in pressure switch. It'd be a 5 minute swap if it wasn't for the pan & fluid hassle.
    Ultimately you need to put a pressure gauge on the transmission and verify pressure rise if there's any question at all about TV adjustment. They don't tolerate much.
    good luck
  6. pigwilliams
    pigwilliams
    No, the positive wire is wired to the pressure switch located in throttle body. nothing out of the normal on this... That's why i'm thinking converter.
  7. pigwilliams
    pigwilliams
    Trans. shop said to wire just like that. There are already a handful of wires and a screw in pressure switch. Thanks.
  8. squirrel
    Try disconnecting the power wire from the trans and see how it works...quick easy test
  9. pigwilliams
    pigwilliams
    I'll go up to the shop today and try it. I'll update later today, keep everyone posted.
  10. Too much cable pull at idle/too high an idle.
  11. pigwilliams
    pigwilliams
    What would be correct idle in drive? It's at 700 in drive.
  12. Shifty Shifterton
    Shifty Shifterton
    That's what the stock stuff is too. Might be worth some investigation, most standalone conversions also include an external vacuum switch. But you really gotta know line pressure too.
    good luck
  13. I assumed you had the 4th pressure switch in place. I suppose it could be bad. (closed) Is it wired through the brake light switch too?
    Just disconnect it at the fuse block. The converter won't stick in lockup mode , once the fluid flow reverses.
    If it still won't downshift to low, back the cable off a little.
  14. pigwilliams
    pigwilliams
    Thank's Markyac, goin' to the shop now. I'll leave an update when i get home. Thank's Shifty and Squirrel.
  15. pigwilliams
    pigwilliams
    UPDATE, after disconnecting the lockout from ignition/ fuseblock.
    Trans. down shifts now. Thank's to everyone who responded.
    It was really nice drivin' the car down to the beach!
    H.A.M.B. Rules!!!!!
