Technical Bad Voltage Regulators
Discussion in 'Traditional Hot Rods' started by chiro, Jan 17, 2025.
  1. patsurf
    patsurf
    i've always believed it was the field windings that need to be polarized in the gen. ...
    chiro and TrailerTrashToo like this.
  2. chiro
    chiro
    Welp...the third VR tested out bad at the rebuilder's shop. He's actually questioning the integrity of his testing equipment and told me to slap it on the car to see if it was working in case there was something wrong with his test bench. Nope. It's dead alright. Gonna order up the Lucas (shudder) electronic VR and see how that goes. I will say that the return process with RockAuto on this current bad VR was seamless and easy. They even sent a pre-paid return label.
    Andy
    RodStRace, e1956v and Algoma56 like this.
  3. jaracer
    jaracer
    You do not polarize regulators, you polarize generators. You only need to do this if the pole shoes in the generator have lost their magnatism. You send current through the field coils in the normal operating direction which will add enough magnetism to get the generator charging.
    chiro, Truckdoctor Andy and patsurf like this.
  4. e1956v
    e1956v
    Alliance Vendor
    Yes, I understand this, but the person asking the question may not have. My point was do not attempt polarization with this regulator or you will destroy it because of the type that it is.
    jaracer likes this.
  5. chiro
    chiro
    Update...
    There's a knowledgeable old timey Ford generator restorer guy in my town. Found him on the Barn. Brought my gennie to him and he opened it up to have a lookey. He found that the previous 12V conversion set the gennie up for an "A" circuit which differs from the standard "B" Ford circuit. This is why the GM regulator I had worked so well, even though it only lasted a year. Anybody have a reliable recommendation for an "A" circuit 12V regulator?
    Andy
  6. RodStRace
    RodStRace
    That guy! If possible, buy from him too. Support your local tradesman.
  7. chiro
    chiro
    ^^^ Yeah. He only does generators, no regulators.
  8. chiro
    chiro
    Anybody have a part number for an "A" circuit 12V regulator for a generator? I'm still looking. Thanks in advance.
    Andy
  9. I would think any GM 12v regulator would work. Because it is a homemade generator you don't know how much current it can handle so get a regulator that is set for lower output current wise.
  10. so looking in a '68 motors manual I see a '62 ChevyII regulator #1119000 that has 25 amp output.
    Also a #1119001 has a 30 amp output
    For vette and other Chevys,
    1119002 has 35 amp output
    Not knowing what your armature can handle I would stick with the 25 amp unit moving up to the 30 amp only if needed.
    Maybe it would be a good plan to start over with another known generator and get the regulator to go with it. I have 3 cars with generators and they are very dependable ....
    I guess these are GM part numbers
  11. e1956v
    e1956v
    Alliance Vendor
    The reason for this is because the quality of new regulators is so bad across the board that you can’t stand behind what you sell. A lot of new regulators don’t even work under ideal test bench conditions, let alone on vehicle with vibration and questionable wiring and bad electrical connections that exist on your customers car. You can only eat so many regulators to keep a customer happy and your reputation intact, even our suppliers won’t constantly warranty their new regulators so the shop ends up eating the cost. After a while you just say no more and stop selling them, you let the customers take the risk and buy their own.
    I know this sounds ****py but it’s just the way it is anymore.
  12. RodStRace
    RodStRace
    @e1956v I completely understand, the shop can't supply or suggest garbage and that's what's out there.
    I had hoped the 'old guy' would have some positive info or direction for him. It hurts his solid honest business when he can't offer even a possibility of the other part of the system. :(
    Truckdoctor Andy likes this.
  13. eBay an New Old Stock Replacement regulator, I can look one up tonight when I get home. No warranties but they're good quality old brands.
  14. chiro
    chiro
    Currently searching for an electronic regulator. There's a place I found online that will convert your electro-mechanical VR to solid state. Waiting on a call back/email response. Called another shop I used to deal with when I lived in NY and the owner says that when a customer requests he also supply a VR, he automatically orders three of them because it's likely that at least one and usually two are bad. The quality is absolute garbage. Another generator COULD be sourced but this would be difficult as I'm running the radiator fan for the flatty mounted to the gennie and those aren't easy to come by. A new gennie would also need to be converted to 12V. There's really no reason to replace the gennie I have as it is working fine, putting out 18V and 25 amps on the test bench. Upon opening it up, it appears it was converted to 12V by changing out the field coils and not the armature which is a common conversion. The armature is fine, commutator is good, brushes good, bearings good. I just need a good voltage regulator and I'll be set. Apparently not an easy thing to find these days. When I built ny '55 Chevy 1/2 ton with the '58 235 I6 (!2V stock gennie), I went to the FLAPS about 12 years ago and slapped a 12V regulator in it and it's been trouble free since. Everybody I talk to latley in the business is comp[laining how the quality of new VR's is garbage. An NOS regulator is an easy thing to source but there's no guarantee that it will be any good off eBay. A 40 year old NOS VR can have it's own issue from laying around who knows where for that period of time. Will it be rusty inside? Will the contacts be dirty? Will there be other issues from age? Is what's printed on the box actually what's IN the box, etc.? Go ahead and try to return that. Good luck. Think I'm going to order an "A" circuit VR from RockAuto because their return policy is just so good, but at this point I'm going to hold out for an electronic version or a shop that will convert my old one to electronic. It's pretty obvious that even if I get a mechanical one, the quality is so bad that it won't last. That's what got me to where I am now. Charging system was working great with the "A" circuit mechanical VR until it failed in less than a year.
    Andy
  15. I just sold my old generator and regulator off of my Chevy panel and the only other I have is for an alternator. I'll look tonight, I think the 90s Standard Ignition was electronic.....if I remember correctly. My Elco had one, I'll see if I still have it. Personally I still would gamble with an old one off eBay, just look for a clean box from a dry state and clean it out when you get it. I bought a bunch of NOS and NORS points and condensers that I use, every once in awhile I have to take a file to the points on first install.
  16. seb fontana
    seb fontana
    from ct
    Early to mid GM like listed above. Took me SEVEN regulators, this was over 15 years ago and "kit" was supposed to be plug and play. If I remember right they were Echlin brand out of NAPA. They had a 2 year warranty and would usually **** out before expiration, last one [35amp] has about 7 or 8k and it charges most of the time, every once in a while it takes a rest but pops back.
  17. This is for an alt but fun watching:
  18. chiro
    chiro
    Update,
    I saw that video above before you posted it and contacted the company yesterday. The owner, Larry, is our kind of guy. He builds electronic VR's in any configuration you want, 6V, 12V, "A" or "B", negative or positive ground. You may need to send in your core or he may have one on the shelf he can build. Mine's been ordered. Looking forward to settling this persistent problem once and for all. I also sent his info to the Ford generator restorer guy in my town and my old rebuilder in NY for their future use for customers. Website below.
    heielectric.com
    Andy
    Algoma56 and big duece like this.
  19. big duece
    big duece
    from kansas
    What would it take to have your generator set up for the "B" Ford style? I really like the idea of e1956v suggestions of the Lucas regulator.
  20. chiro
    chiro
    ^^^ I asked. It obviously can be done but would be a bit of a h***le to set it up. The gennie is working fine the way it is and if it ain't broke...
    I just need a reliable "A" circuit regulator.
    Andy
  21. sidevalve8ba
    sidevalve8ba
    I've got to wonder why it was set up for an A regulator to begin with? It is a Ford generator, correct?
    alchemy likes this.
  22. big duece
    big duece
    from kansas
    How much more h***le would it be to set it up for "B" circuit? Couldn't be any more h***le than what you've already been through.
    sidevalve8ba likes this.
  23. Beanscoot
    Beanscoot
    The irony is that the makers of these terrible parts are rewarded by the public buying multiple pieces of their ****.
    Truckdoctor Andy and big duece like this.
  24. chiro
    chiro
    Final update (hopefully) for those following along. Got the electronic VR from Hagemeister Enterprises the other day and slapped it in the coupe. Works perfectly. Better than the last mechanical one that worked well. Great service from great people. I finally have a charging system I don't have to constantly worry about.
    Andy
  25. Adriatic Machine
    Adriatic Machine
    What is FLAPS? I live on Long Island and I’m not familiar.
    I’m glad to hear you got your charging system all squared away
  26. Friendly Local Auto Parts Store?
  27. MAD MIKE
    MAD MIKE
    from 94577
    Out of curiosity, of all these 'bad' mechanical regulators has anyone here diagnosed, or had diagnosed, the failure mode?
    Bad coil windings?
    Bad contacts?
    Too weak/strong return springs?
    Bad resistors?
    Bad solder joints?
    Bad board and/or traces?
    Something else?
    Is it really shoddy regulators or are these regulators undersized for a given generators capacity and simply incorrectly rated.
    Cheap DVM and some quick probing may reveal a fault.
    Adriatic Machine likes this.
  28. fabricator john
    fabricator john
    from venice fl.
    half the time this is the problem
    fabricator john
    miss you dad
