Projects Bagged 55 Buick build
Discussion in 'The Hokey Ass Message Board' started by EVL401, Feb 6, 2015.
  1. EVL401
    EVL401
    G'day from Oz!!
    Bout a year ago I purchased a "complete 55 Buick" from a guy up north in Australia. He had imported it from the good ol USA!! I Had it inspected & was told it'd be running in a coupla weeks so I bought it. When I finally got it home it was a mess!! Lotsa bits missing, seized 264 nail, no brakes inside the drums, 2 bolts barely holding each bumper on, one bolt holding Trans onto the motor, basically a nightmare!! However one thing it did have going for it was the rust free body!!
    After few days of thinking what have I done I swallowed deep, imagined the fully built 55 Buick I've always wanted & ripped in to a total rebuild!!
    This is the story........
  2. EVL401
    EVL401
    The first day I got it........
  3. EVL401
    EVL401
    The seized 264 nail........ Incomplete & totally ******ed!!
  4. EVL401
    EVL401
    3 ****ty bolts later, out it came.....
  5. EVL401
    EVL401
    No brakes!! NONE!! Only an empty drum on each corner of the car.
  6. EVL401
    EVL401
    So after some planning on what I wanted the car to be, I cut floor pan out & started planning a 4 link conversion. Car will run 401nailhead, T700 auto for highway cruisin & a ford 9" diff. Brakes front & rear will be converted from late model Holden Commodore. Full Accuair Airide setup front & rear too. Slam bags front & rear.
  7. EVL401
    EVL401
    2" Fatman drop spindles on the front....
  8. ph8ed4life
    ph8ed4life
    from AZ
    Yes, I love Buick builds! Good luck_
    -Matt
    EVL401 likes this.
  9. EVL401
    EVL401
    Makin bag plates for lower front arms & also got rid of factory front mounts. Kinda wanted to start this thread as there's a lot of questions about putting a bigger nailhead in earlier buicks but not many pics of engine mounts, gearbox mounts etc etc. why not do***ent it as I go.....? Hopefully will help another HAMB member down the track looking to do similar conversion....
  10. EVL401
    EVL401
    Stock 15's blasted & painted hi gloss 2pk with bit off Mooneyes spider cap bling
  11. EVL401
    EVL401
    The hubs have been machined out to upgrade a newer, better bearing setup inside them. Drums rivots obviously drilled out & bigger studs put in ready for disc brake conversion.....
  12. Fulvia
    Fulvia
    Repaint the car the same color. I've always loved that blue.
    EVL401 likes this.
  13. belair
    belair
    I hate being lied to on a deal. Glad you are pressing forward.
    EVL401 likes this.
  14. EVL401
    EVL401
    Visited Mooneyes mid 2014 they hooked me up with some cool ****!! Purchased 6x2 Weiand dragstar manifold from Russ Martin however still hesitant to run it. Not keen to be tuning these ****ers every few weeks so at the moment the 401 sporting a standard 4 barrel manifold.... However I just couldn't resist some pics with manifold & carbs on there!!
  15. EVL401
    EVL401
    Was trying to work on front end & engine mount design until I got sick of it & completely stripped everything off it!! The rabbit warren gets deeper, however access is much easier.....
  16. EVL401
    EVL401
    Pulled out all the remaining "electrical spaghetti" & purchased a complete Painless wiring kit. Had few choices of wiring kits but went with painless & thus being colourblind it's fitting that every single wire in its kit it is labelled on the outer insulation......
  17. EVL401
    EVL401
    First pics shows stock upper control arms cleaned ready for paint & new bushes etc.
    2nd pics shows inside spring tower on front end with factory top plate to locate top of spring. This ****er is rivoted in & they need to be drilled & punched out from the top of the ch***is. Later pics will show the plate I've made to bolt in its place......
  18. EVL401
    EVL401
    Top bag locating plate bolted in. Used the old top spring plate as a template.
    Bag sitting in its future home!! Although lately been doing a lot of research whether to set up front end with airbag at relaxed height/preferred driving height or slammed position. Think the bag being at relaxed height as shown in pic will need a spacer or cup to nestle it in there. Watch this space!!
  19. EVL401
    EVL401
    Bags on front are Slam Specialties RE-6. Will be using Slam RE-7's on rear....
  20. EVL401
    EVL401
    Rear Trans mount a mate fabricated. Looks good!!
  21. EVL401
    EVL401
    Engine mount almost done for one side. The 401 bit bigger than the little brother 264 so little concerned about exhaust clearance for steering box........
  22. DSCN9576.JPG I'm running the 6 two set up on my 322 Nailhead, the center carbs are not functional, runs great. Russ has helped me a lot these last few years, good guy. My parents bought a new 55 Buick, same color as yours, cool car.
    EVL401 likes this.
  23. EVL401
    EVL401
    In the meantime we bagged my mates 54 Plymouth, learning a lot along the way..... Definitely gave me few ideas for my 55'
  24. EVL401
    EVL401
    Thanks everyone for words of encouragement & damn 1927graham that looks tastey!! How's it go with 4 carbs? Functioning carbs?
  25. EVL401
    EVL401
    Pic of the booster/master that goes with the late model commodore front & rear disc brake setup. I wanted to run this under the dash at a right angle but due to its size it may not work.
    Here in Australia if u even slightly modify your vehicle you basically need an engineer to sign off on your modification. Although it's a good idea & a safe one it can also be a royal pain in the ***.
    A mate of mine bought a set of big Outlaw front calipers & discs for his street machine from USA & the engineer wouldn't sign off on the modification as the calipers had no dust seals on the Pistons. Choose your engineer & modifications for that matter wisely!!
  26. That's gonna look killer bagged man!
    EVL401 likes this.
  27. EVL401
    EVL401
    Despite what some ppl may say, you'll have to run a sump with a hump at the back. The 401 I bought came with a centre hump sump so I had to track one down. A mate had one from an earlier 364 which fits however the oil pickup is of a different type. I will be modifying the pickup tube in my 401 to suit the rear hump oil pan.
  28. EVL401
    EVL401
    Researched a fair bit about engine/Trans angles when custom makin engine mounts. Been told between 2-3 degrees is perfect but also carb base on manifold must be completely flat!! So bought a digital spirit level gauge & with the carby base perfectly flat (after I leveled the ch***is as I am building it to be parallel at ride height) it was reading 5 degrees. I thought this was rather excessive but after further research found that some motors actually sit in engine bays as much as 6 degrees. Can anyone elaborate on this.....?
    I've only tacked the ch***is side of engine mounts in at this stage........
  29. EVL401
    EVL401
    Standard exhaust manifold with the lack of clearance to the steering box. Bought some blockhuggers/extractors/headers & they fit a little bitter with a very small amount of clearance. At this stage I'm tossing up whether to modify them or just start from scratch .....
  30. Moto Moto
    Moto Moto
    from Krum, TX
    *****in build my friend. Love it.
    EVL401 likes this.
