Technical Bagged shoebox ride height?
Discussion in 'The Hokey Ass Message Board' started by Shywaz, May 22, 2024.
  1. Shywaz
    Shywaz
    from LTU
    Hi,
    Another question from new Euro shoebox owner :)
    Planning to swap rear axle, getting Ford Explorer 8.8, and at the same time I'd like to install air bags.
    How low can i go before i hit frame or tire wells (stock wheels)?
    Would you reccomend C notching a frame? Or its not worth the h***le, result is minimal with max effort?
  2. Well. You can check with tape measure
    Measure how high the car is off the ground stock
    If the rocker is 8 inches from the ground, use that measurement to figure out where the rear axle will be at the drop you want
    Pist-n-Broke likes this.
  3. And there's your answer. It's a priceless Tool.
    anthony myrick likes this.
  4. Shywaz
    Shywaz
    from LTU
    Only problem is that i dont have the car yet:) waiting for it to arrive on late June - early July
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    This belongs in the OT forum.
    I can see the opening of the rabbit hole.
