Bagging a '50 Shoebox Ford ?
Discussion in 'The Hokey Ass Message Board' started by CJ Hilton, Mar 29, 2006.
  1. CJ Hilton
    CJ Hilton
    Looking for some suggestions, advise and help on bagging a 50 Shoebox Ford.
    Basically what’s involved, pros & cons on the different types of systems.
    I’d like to be able to maintain a good ride but slam her on the ground when parked.
    I’m not interested in the up & down side to side or corner to corner.
    I would like to have skid plate so if I drop the ass end she’ll throughout some sparks. Any ideals? Thanks CJ
  2. extremist
    extremist
    There's a lot of information already in here on various threads. I've subscribed to numerous threads by using the search feature to find them.
  3. PorkChop
    PorkChop
    from Austin
    Well when I did my coupe, like ummm 7 years ago..
    My memory has faded...to say the least since then.. lets see if I remember what we did.
    Front -
    Remove springs..duh.
    Cut lower a arm spring mount thing.. weld in new cup for bag, weld in top cup..fab shock mounts...
    Rear -
    Pulled a few leafs...mounted bags on shock mount "plate" , and then made a mount to the top of the frame rail..
    run lines, compressor/tank in the trunk...
    voila..
    With it parked and totally empty (air) , the rockers sat about 1 pack of smokes on their back, from the ground., and I could drive it a few inches above that..
    I ran BF Goodrich radial whitewalls..15" ....and never had a problem clearing speed bumps, cats, chihuahuas, or driveways...
    I did end up putting in better line, ie: stronger...and valves to balance side to side.. the body roll used to suck..
    I would suggest sway bars front and back..
    The setup worked for me.. but I am redoing some of it, before I sell it, to make it more betterer..:D
    Anyway...hope this fuzzy info helps.
    Later.
    PC
