Technical Bagging a Shoebox
Discussion in 'The Hokey Ass Message Board' started by Custompainter99, May 7, 2015.
  1. Custompainter99
    Custompainter99
    from San Jose
    Looking to air bag the front of my shoebox with a stock front end. What cups/ bag mounts do i use? i've seen some use a ford ranger bag cups, some S-10's....any suggestions?
  2. Custompainter99
    Custompainter99
    from San Jose
    sooo. no one baggs their shoebox fords?
  3. trailerpark
    trailerpark
    Guess not, sorry. I have put bags in the trunk, but they were filled with food. Good luck
  4. How about bagging on a shoe box.
    Ok that gets you back up on top. ;)
  5. DERPR30
    DERPR30
    from HARVEY LA
    ONLY BAGS I HAVE ARE FULL OF BEER & CIGS
  6. wbrw32
    wbrw32
    Bags are for groceries.......
  7. Jalopy Joker
    Jalopy Joker
    only know of kits for bagging rear - Gambino Kustoms
  8. earthbound
    earthbound
    What year shoe box? I made custom cups for my 55 ranch wagon. PM me if you have any questions
  9. Custompainter99
    Custompainter99
    from San Jose
    its a 1950
  10. earthbound
    earthbound
    Unfortunately your front end is different than mine. Sorry wish I could help you out.
  11. gearheadwelder
    gearheadwelder
    from CT.
    You'll need to search deeper here on the HAMB, I've looked over lots of in-depth posts on different ways to bag the stock front end. It's not always the best platform to start with depending on what it is you want for drop. If you want to lay frame, Gambino rear kit is tops in my book, as for the front, camaro clip or new stub clip like Fatmans.
  12. 303 D
    303 D
    I installed the ride tech cool ride set up trimmed the top cup an inch and a half grinded out the spring pocket to clear the bag and welded eighth inch plate to the lower and mounted the bag to that took a couple hours and set the car about three inches from the ground but I still don t have the dropped uprights.
  13. ACO.OG
    ACO.OG
    ^^^ what he said.
    You can make your own cups. They make "cup kits" but some 4" round pipe/tube and some bag plates would probably be cheaper.
    Not sure how shoebox front suspension is set up but you can try stepping your lower arms to avoid buying drop spindles if you're on a budget.
  14. uglysteve
    uglysteve
    Well it's not a shoebox but i'm bagging my plymouth and for the front i ordered this.
    Just cut it to the length you need and weld on the plate. Try searching on here too there's gotta be a bunch of threads on it.
