1952-59 Ford bagging my 55
Discussion in 'Off Topic Hot Rods & Customs' started by jakes55, Aug 6, 2012.
  1. jakes55
    jakes55
    from ohio
    What are some thoughts on this? I don't want to c notch the frame but id like to be lower than what I am now. I'm young, dumb and want to have fun. Any pictures of set up in rear and what type of bags you recommend?
  2. dragonknucks
    dragonknucks
    How low do you have it now? Dropped spindles and Aerostar springs up front will get you pretty low. Then some 3"-4" blocks out back will also get it pretty low. Good luck on the bags without notching the frame. But if you want it on the ground, that's what you are gonna have to do.
  3. 53vicky
    53vicky
    if you dont notch it your not going to get it "low enough"
    im a strong promoter of 4" blocks and aerostar springs.
  4. " Bags are for groceries !" :D
  5. Dos Cincos
    Dos Cincos
    Where are you guys getting your 3"- 4" blocks and are you getting the ones with a pinion angle?
  6. jakes55
    jakes55
    from ohio
    I have the the spring pocket spacers and 2 inch blocks in the rear. I didn't find you guys until everything was ordered and on. The problem I have is that bottoming out in the front. I know if I get the aerostar springs, it will be worse. I also need to look into a different throw in the shock to help this problem out. If I do bags, its not to sit on the ground, its just about the stance at the show and to not be on the ground completely
  7. EchoOfGecko
    EchoOfGecko
    You shouldn't bottom out with uncut Aerostar springs up front, but if you cut them or add pocket spacers you might. The best next step for going lower up front would be drop spindles, as they will give you a couple extra inches without changing your suspension geometry. Smaller diameter tires would help too.
    For the rear, you probably won't be able to go much lower than 4" (blocks or bags) before you start running in to drive-line clearance issues, so anything lower than that and you'll need to start doing floor work.
    I would just stick with Aerostar springs and maybe spindles up front, and 4" blocks out back, and then start saving up for a bag set-up to go lower.
  8. jakes55
    jakes55
    from ohio
    What are you paying for 4 inch blocks and from where?
  9. dragonknucks
    dragonknucks
  10. jakes55
    jakes55
    from ohio
    I didnt know if there was a place who sold them cheaper. Thats who I have been going through this hole time.
  11. 55zing
    55zing
    from victoria
    i went triangulated 4 link and shock waves, took ot the bump stops, did not notch the frame bit did some trunk mods,
  12. jakes55
    jakes55
    from ohio
    Could you post some pictures of the four link? And the pictures you have, is that with the bags all the way empty? The car looks great 55zing
  13. 55zing
    55zing
    from victoria
    the pics are at ride height, will be taking the body off for the last time in a couple of weeks, ill take some pics for you
  14. jakes55
    jakes55
    from ohio
    Thank you very much
  15. 55zing
    55zing
    from victoria
    hey just added some pic of the 4 link more comming good luck
  16. fordsbyjay
    fordsbyjay
    from Lafayette
    Here is a link to your album for those that have no idea where you put the pictures.
    55's photo album
  17. 53vicky
    53vicky
    dos - you can get them from jamco and thenightprowlers
  18. jakes55
    jakes55
    from ohio
    I appreciate all the feed back!
