Technical Baileigh 3 in 1
Discussion in 'The Hokey Ass Message Board' started by SMH, Feb 1, 2015.
  1. SMH
    SMH
    Anyone have the 5216 machine? How does it do when shearing and braking 16ga? Anyone have any experience. Looking at these would be good because they take up less room than two separate machines but want to make sure it does what it says.
    Thanks
  2. HOTRODPRIMER
    HOTRODPRIMER
    Baileigh don't sell junk,that looks like a quality built piece of equipment. HRP
  3. SMH
    SMH
    I have seen the videos but no video rolling or shearing 16ga of and width.
  4. HOTRODPRIMER
    HOTRODPRIMER
  5. SMH
    SMH
    Will do. Thanks!
  6. SMH
    SMH
    Anyone have any personnel experience with this shearing 16ga.
  7. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    I think SMH has it right by asking guys that own/use one about it rather than the manufacturer/owner. Im sure if you ask the Hoffman group if they make good products they will say "yes" and we all know about their quality.
    Now before anyone ***** bunches, I'm in NO WAY comparing Baileigh Inc to Hoffman Group, so save the drama.
    If it were any other company and the guy posts later "I wasnt impressed with the quality vs what the manufacturer claimed" the thread would have 800 posts saying "what else did you expect them to say? Why didnt you ask on the Hamb from users of it?"
    Just sayin' ;)
  8. stealthcruiser
    stealthcruiser
    I'd love to hear how it performs, as I have never seen one of those "multi-machines" live up to it's claims.
    The majority that I have seen, and even badged from different manufacturers, usually had a break in some section of the frame casting.
    I was not aware that Baileigh sold one.
  9. SMH
    SMH
    Yes would like to have some comments from someone that has one.
    Thanks
  10. PBRmeASAP
    PBRmeASAP
    Prewar....good point!
    I've looked at that too and wondered...
  11. seb fontana
    seb fontana
    from ct
    16ga my be on the thick side, about .045? [from memory]..
  12. SMH
    SMH
    Do you have one?
  13. SMH
    SMH
    Nobody has one?
  14. gimpyshotrods
    gimpyshotrods
    Having used most everything else they make, and were I in the market, I would buy it in a heartbeat.
  15. This is basically just a better-quality version of the one HF currently sells only wider. In fact, other than the width it looks exactly the same as the one I got from HF about 10 years ago. Same end castings, handles, etc. The current HF offering looks much lighter-duty. FWIW, mine has been OK although I did break one of the cast actuating arms. I made new ones out of 1/2" steel plate, no more issues. Most of this stuff comes out of the same Chinese factory, with individual resellers specifying quality/features/tolerances.
    I guess the main issue with these machines is like any 'multi-purpose' unit, compromises have to be made in operation. The biggest flaw IMO is the press brake. Unlike a conventional brake, these pretty much only bend 90 degree bends accurately. Less angle and the material isn't pressed into the die all the way and you don't get a consistent bend, plus you'll get a different radius at different angles. You're also stuck with the built-in bend radius when bending at 90 degrees unless you want to build custom fingers and even then you'll be limited to about a 1/4" radius. Another issue is the 'material clamp' (which looks identical to mine only wider) on the shear is inadequate to hold the material firmly enough on wide cuts; I use vice-grips on mine when needed as I found the clamp to be nearly useless. For the smaller work I use this for, I'm reasonably happy with mine, it doesn't take up a lot of space, but I just don't see one of these doing the claimed width. For the money this machine costs, I'd go with standard single-operation units instead and figure where to put them.
  16. HOTRODPRIMER
    HOTRODPRIMER
    I can ***ure you that you don't want a Harbor Freight 3 in 1 tool.
    It's a real POS! :mad: HRP
  17. Yep, that's where mine broke... Built new arms out of steel, no issues since.
    The Baileigh machine appears to have the same cast arms, I'd ask before I bought.
  18. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Mine broke there too. Easy to fix, never had an issue afterwards.
  19. SMH
    SMH
    Yea it's a tough decision. I know they make good stuff. But for 2k I want it to do what it says. I can't find any real life experience with anyone that has one.
